EM05-G Android Integration Problems / invalid ttyUSB used for AT
Hey,
we are trying to integrate the EM05-G 4G module into our android system.
Android Version 12.0
But we are facing problems.
ril version and status:
getprop | grep ril
[gsm.version.ril-impl]: [Quectel_Android_RIL_Driver_V3.5.13-20221027-tianqi_dirty]
[init.svc.ril-daemon]: [running]
[init.svc_debug_pid.ril-daemon]: [516]
[ril.function.dataonly]: [1]
[rild.libargs]: [-d]
[rild.libpath]: [/vendor/lib64/libquectel-ril.so]
[ro.boot.noril]: [false]
[ro.boottime.ril-daemon]: [10732597476]
[ro.ril.ecclist]: [112,911]
[vendor.rild.libpath]: [/vendor/lib64/librk-ril.so]
dmesg output shows the modem is discovered and the devices are created:
usb 5-1.4: new high-speed USB device number 3 using ehci-platform
usb 5-1.4: New USB device found, idVendor=2c7c, idProduct=030a, bcdDevice= 3.18
usb 5-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 5-1.4: Product: Quectel EM05-G
usb 5-1.4: Manufacturer: Quectel
option 5-1.4:1.3: GSM modem (1-port) converter detected
usb 5-1.4: GSM modem (1-port) converter now attached to ttyUSB0
option 5-1.4:1.2: GSM modem (1-port) converter detected
usb 5-1.4: GSM modem (1-port) converter now attached to ttyUSB1
option 5-1.4:1.5: GSM modem (1-port) converter detected
usb 5-1.4: GSM modem (1-port) converter now attached to ttyUSB2
cdc_mbim 5-1.4:1.0: cdc-wdm0: USB WDM device
cdc_mbim 5-1.4:1.0 wwan0: register 'cdc_mbim' at usb-fc880000.usb-1.4, CDC MBIM, 66:ad:99:88:e6:99
output of logcat -b radio -v time, this is cyclically printed
D/RILU    (  536): find quectel module /sys/bus/usb/devices/5-1.4 idVendor=2c7c idProduct=030a
D/RILU    (  536): find_usb_device is 1
D/RILU    (  536): find /sys/bus/usb/devices/5-1.4:1.2/ttyUSB2
D/RILU    (  536): ttyAT = ttyUSB2
D/RILU    (  536): find /sys/bus/usb/devices/5-1.4:1.5/ttyUSB3
D/RILU    (  536): ttyPPP = ttyUSB3
D/RILU    (  536): find /sys/bus/usb/devices/5-1.4:1.3/ttyUSB1
D/RILU    (  536): ttyDM = ttyUSB1
E/RILU    (  536): unknow bInterfaceClass=, bInterfaceSubClass=
D/ATC     (  536): AT> AT+CFUN=1,1
D/ATC     (  536): really time out
the EM05-g discoveres with 3 ttyUSB and one cdc-wbm0.
Shouldn’t the module come up with 4 ttyUSB ?
and i would guess:
ttyUSB1 (1.) → DM
ttyUSB2 (2.) → GPS NEMA
ttyUSB3 (3.) → AT
ttyUSB3 (4.) → PPP (but this device is missing)
but as we have the cdc-wdm0 i think we don’t need the PPP device is this correct ?
but somehow the ril discoveres the wrong ttyUSB for communication or ? its using ttyUSB1 but should use ttyUSB3
also i am missing ttyGPS = XXX the ril should also discover gps or ?
could someone give me a hint what we are dooing wrong ?
and could you please also send me the latest firmware for the em05-g module.
Thanks and best regards
Julian
we were able to get the modem up by fixing some parameters in the kenel.
option.c
wwan_qmi.c
wwan_qmi_q.c
As the modules comes up with 6 interfaces not 4 and the first 2 are missing in qmi mode.
but we are facing another problem now.
A-GPS is not working.
we “see” satelites but we can’t get a fix
also a-gps is not working
we created a gps.conf in /etc/ but this file is ignored …
regards
gps logs:
01-31 16:39:28.638 D/GPS ( 523): ql_gps_receive_cmd_from_gps_hal = {type=6, length=2}
01-31 16:39:28.638 D/GPS ( 523): onGPSStateChange = {type=6, length=2}
01-31 16:39:28.638 D/ATC ( 523): AT> AT+QGPS?
01-31 16:39:28.638 D/GPS ( 523): ql_gps_receive_cmd_from_gps_hal = {type=1, length=0}
01-31 16:39:28.642 D/ATC ( 523): AT< +QGPS: 0
01-31 16:39:28.642 D/GPS ( 523): ql_set_gnss_modle: the gnss mode is [Stand-alone] alerady.
01-31 16:39:28.642 D/GPS ( 523): onGPSStateChange = {type=1, length=0}
01-31 16:39:28.642 D/ATC ( 523): AT> AT+QGPS?
01-31 16:39:28.644 D/ATC ( 523): AT< +QGPS: 0
01-31 16:39:28.644 D/ATC ( 523): AT> AT+QGPS=1
01-31 16:39:28.652 D/ATC ( 523): AT> AT+QGPSXTRA=1
01-31 16:39:28.658 D/ATC ( 523): AT> AT+QGPSXTRADATA?
01-31 16:39:28.663 D/ATC ( 523): AT< +QGPSXTRADATA: 0,“1980/01/05,19:00:00”
01-31 16:39:28.663 E/GPS ( 523): ql_xtradata_inject_time :1980/1/5, 19:0:0
01-31 16:39:28.663 D/ATC ( 523): AT> AT+QGPSXTRA=0
01-31 16:39:28.671 E/GPS ( 523): start_xtra_expired ENTER
01-31 16:39:28.671 E/GPS ( 523): check_xtradata_file_durtime xtra_time :1980/1/5, 19:0:0
01-31 16:39:28.671 E/GPS ( 523): check_xtradata_file_durtime now_time:2023/1/31, 16:39:28
01-31 16:39:28.671 D/GPS ( 523): ql_send_to_gps_hal_thread start.
01-31 16:39:28.671 D/GPS ( 523): ql_send_to_gps_hal_thread end.
01-31 16:39:28.681 D/GPS ( 523): ql_gps_receive_cmd_from_gps_hal = {type=4, length=29}
01-31 16:39:28.771 E/GPS ( 523): start_xtra_expired EXIT
01-31 16:39:28.771 D/GPS ( 523): ql_send_to_gps_hal_thread start.
01-31 16:39:28.771 D/GPS ( 523): ql_send_to_gps_hal_thread end.
01-31 16:39:28.772 D/GPS ( 523): onGPSStateChange = {type=4, length=29}
01-31 16:39:28.772 D/GPS ( 523): ql_inject_time(time=1675182964431, timeReference=43716, uncertainty=10)
01-31 16:39:28.772 D/ATC ( 523): AT> AT+QGPSEND
01-31 16:39:28.776 D/ATC ( 523): AT> AT+QGPSXTRATIME=0, “2023/1/31,16:39:28”,1,1,10
01-31 16:39:28.781 D/ATC ( 523): AT> AT+QGPS=1
but supl host is not set and also xtra data is not pushed
also AT+QGPS = 1 shouldn’t this value be set to AT+QGPS=2 ?
Hi julnisch,
AT+QGPS=1 just to open GNSS, before you use GNSS function, pls make sure you connect gnss antenna well and in an unobstructed environment, preferably outdoors, make sure you can receive GNSS messages, thanks.
@Duncan.Xu-Q why initial xtra time is so strange? I’d expect something like ‘1980/1/6, 0:0:0’ at least. Is it UTC or it depends on the timezone?
