EM05-E dont attach to Vodafone data only, AT+CGATT=1 fails
we have an EM05-E which does not attach to “Vodafone DATA ONLY” via LTE. This card is a roaming card, and without voice support.
AT+CGATT=1 all times returns an error after 60 Seconds.
// Firmware
ATI
EM05EFAR06A06M4G_01.200.01.200
// Enable verbose error values
AT+CMEE=2
// Check SIM
AT+CPIN?
+CPIN: READY
// Query IMSI. operator id: 90128, Vodafone's Global Data Service Platform, Roaming SIM
AT+CIMI
901280023145962
// Check avalable operators. 3x LTE operators are here
AT+COPS=?
+COPS: (1,"vodafone.de","Vodafone","26202",7),(1,"o2 - de","o2 - de","26203",7),(1,"Telekom.de","TDG","26201",7),,(0-4),(0-2)
// Check, that modem try to attach by self. yes
AT+CREG?
+CREG: 0,2
// Check state of attach. Not attached
AT+COPS?
+COPS: 0
// Force attach. Give an error after 60 seconds
AT+CGATT=1
+CME ERROR: no network service
// Check indicators. 2: Signal good (0-5), 1: Registered to the roaming network
AT+CIND?
+CIND: 0,2,0,0,1,0,0,0
// Get extended error
AT+CEER
+CEER: 6,259
Same card in an EC25-E or EG25-G will attached and internet connection works.
An other card in this EM05-E works, also with roaming, operator 1nce, like vodafone data roaming.
Additional question:
We see “File Configuration Setting” (QMBNCFG) in the modem.
We have anabled for example the title “VF_Germany_VoLTE”, but not helps.
Need we such special file for “Vodafone DATA ONLY” here? And how we get it into the modem?
Henry
Please show results:
AT+CEREG?
AT+CGDCONT?
AT+CGPADDR
AT+QMBNCFG="List"
AT+CEREG?
+CEREG: 0,2
AT+CGDCONT?
+CGDCONT: 1,"IPV4V6","","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
AT+CGPADDR
+CGPADDR: 1,"0.0.0.0
AT+QMBNCFG="List"
+QMBNCFG: "List",0,0,0,"ROW_Generic_3GPP",0x05010824,201806201
+QMBNCFG: "List",1,0,0,"TW_Mobile_China_VoLTE",0x05800301,202201111
+QMBNCFG: "List",2,0,0,"Bouygues_France_VoLTE",0x05800101,202203031
+QMBNCFG: "List",3,0,0,"VF_Germany_VoLTE",0x05010415,201705111
+QMBNCFG: "List",4,0,0,"Reliance_OpnMkt",0x05011B4B,201801051
+QMBNCFG: "List",5,0,0,"Smartfren_Indonesia_VoLTE",0x05800601,201705111
Commands says not attached, try to find operator again, no IP connection, no IP address, no MBN File used.
Configure your APN, restart the modem and re-check with
AT+CEREG?
AT+CGDCONT?
AT+CGPADDR
Configure APN:
AT+CGDCONT=1,"IP","priv4apn"
Check
AT+CREG?
+CREG: 0,2
AT+CGDCONT?
+CGDCONT: 1,"IP","priv4apn","0.0.0.0",0,0,0,0
+CGDCONT: 2,"IPV4V6","ims","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,0
+CGDCONT: 3,"IPV4V6","SOS","0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0",0,0,0,1
AT+CGPADDR
+CGPADDR: 1,"0.0.0.0"
+CGPADDR: 2,"0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
+CGPADDR: 3,"0.0.0.0,0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0"
Reboot modem:
AT+QPOWD=0
POWERED DOWN
After some seconds, modem is coming back
AT+CEREG?
+CEREG: 0,2
… 2: Not registered, but searching
AT+CGDCONT?
… configuration deleted. I think, it is normal after restart
AT+CGPADDR
AT+CGATT?
+CGATT: 0
AT+COPS?
+COPS: 0
… no addresses, not attached, no operator
Check, what modem is seen …
AT+COPS=?
+COPS: (1,"vodafone.de","Vodafone","26202",7),(1,"Telekom.de","TDG","26201",7),(1,"o2 - de","o2 - de","26203",7),,(0-4),(0-2)
AT+CEER
+CEER: 5,29
AT+CSQ
+CSQ: 31,99
AT+CIND?
+CIND: 0,5,0,0,1,0,0,0
… Indicatiors are very good. I can see Telecom network tower 30 meters from me.
+CGDCONT should be preserved, this is what we see with similar models like EC25.
The output provided shows that there is no MBN selected, so the user defined APN should be preserved.
I’m curious what is in AT+QMBNCFG="AutoSel" output.
+QMBNCFG: "AutoSel",1
it is enabled.
The list is now
AT+QMBNCFG="List"
+QMBNCFG: "List",0,1,1,"ROW_Generic_3GPP",0x05010824,201806201
I will try with AutoSel disable.
jfrog, you are perfect! :slight_smile:
  1. Disable Autosel: AT+QMBNCFG="AutoSel",0
  2. Restart modem: AT+QPOWD=0
  3. Set APN: AT+CGDCONT=1,"IP","priv4apn"
  4. Restart again: AT+QPOWD=0
  5. Check IP:
AT+CGPADDR
+CGPADDR: 1,"10.97.217.93"
The first time, I see an IP with this card in this modem.
Courios, the list is enabled:
AT+QMBNCFG="List"
Some times before I try to disable it with AT+QMBNCFG="Deactivate". But after this all AT+CGDCONT=1,"... failed with ERROR. After a restart the first list was enabled again.
