eID RG520F-EB module
How can I retrieve the eID of an RG520F-EB module?
AT+QESIM=? shows an AT+QESIM=“eid” option, but results in ERROR.
at+cgla=1,10,“81CA005A12” is not working as well.
atcmd /dev/at_mdm0 ATI
RG520F-EB
Revision: RG520FEBDER03A01M8G_OCPU_ZYXEL
Dear @ohne
Do you have a profile of eSIM in your device?
Please use AT+QESIM=“profile_detail” to query.
I can not add a profile since there is no way to add a profile when the eID is not added. The module is inside of a Zyxel NR7302.
root@NR7302:~# atcmd /dev/at_mdm0 AT+QESIM="profile_detail"
ERROR
root@NR7302:~# atcmd /dev/at_mdm0 'AT+QESIM="profile_detail",1'
ERROR
root@NR7302:~# atcmd /dev/at_mdm0 AT+QESIM="eid"
ERROR
root@NR7302:~# atcmd /dev/at_mdm0 'AT+QESIM="lpa_enable",1'
root@NR7302:~# atcmd /dev/at_mdm0 'AT+QESIM="lpa_enable",0'
ERROR
root@NR7302:~# atcmd /dev/at_mdm0 'AT+QESIM="eid"'
ERROR
root@NR7302:~#
Dear @ohne
You can contact with Zyxel and confirm how to add eSIM profie.
The firmware is OCPU, you also need to contact with them about if it support eSIM or not.
