I’would like to install a EG95 on debian 11 on arm64.
All It"s okay until driver installation :
Entering directory ‘/usr/src/linux-headers-5.15.32-v8+’
CC [M] /tmp/files/drivers/./drivers/usb/serial/usb_wwan.o
CC [M] /tmp/files/drivers/./drivers/usb/serial/option.o
/tmp/files/drivers/./drivers/usb/serial/option.c:1979:23: error: initialization of ‘unsigned int (*)(struct tty_struct )’ from incompatible pointer type ‘int ()(struct tty_struct )’ [-Werror=incompatible-pointer-types]
1979 | .write_room = usb_wwan_write_room,
/tmp/files/drivers/./drivers/usb/serial/option.c:1979:23: note: (near initialization for ‘option_1port_device.write_room’)
/tmp/files/drivers/./drivers/usb/serial/option.c:1980:23: error: initialization of ‘unsigned int ()(struct tty_struct )’ from incompatible pointer type ‘int ()(struct tty_struct )’ [-Werror=incompatible-pointer-types]
1980 | .chars_in_buffer = usb_wwan_chars_in_buffer,
/tmp/files/drivers/./drivers/usb/serial/option.c:1980:23: note: (near initialization for ‘option_1port_device.chars_in_buffer’)
/tmp/files/drivers/./drivers/usb/serial/option.c:1987:20: error: initialization of ‘void ()(struct usb_serial_port )’ from incompatible pointer type ‘int ()(struct usb_serial_port *)’ [-Werror=incompatible-pointer-types]
1987 | .port_remove = usb_wwan_port_remove,
/tmp/files/drivers/./drivers/usb/serial/option.c:1987:20: note: (near initialization for ‘option_1port_device.port_remove’)
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:277: /tmp/files/drivers/./drivers/usb/serial/option.o] Error 1
make[1]: *** [Makefile:1868: /tmp/files/drivers] Error 2
make[1]: Leaving directory ‘/usr/src/linux-headers-5.15.32-v8+’
make: *** [Makefile:10: modules] Error 2
I’have tested the same methode with debian 10 and it’s work.
I’ think i have a old version of divers (2019) and debian 11 not done.
Can I’have the last version ?
