EG916Q-GL wifi scan function
Hi all,
I’m working with the EG916Q-GL modem running firmware version EG916QGLLGR01A05M04. I’m trying to scan for nearby Wi-Fi access points using the AT command “AT+QWIFISCAN=12000,1,6,5,0”. However, the command returns nothing. Additionally, both “AT+QWIFISCAN=?” and “AT+QWIFISCAN?” respond with just “OK”, without providing any parameter information.
My questions are:
  1. Does the EG916Q-GL support the “AT+QWIFISCAN” command or Wi-Fi scan functionality in general?
  2. If so, is this functionality supported in the firmware version EG916QGLLGR01A05M04?
Any insights or documentation references would be greatly appreciated.
Thanks in advance!
I have sent the latest firmware to your email,pls check and try again
Hi @herbert.pan-Q
Thank you for your support. Our module is on a custom board and we don’t have access to the GNSS_RST button. Can you provide us the DFOTA firmware from EG916QGLLGR01A05M04 to your latest version. We will try to upgrade via this AT command
AT+QFOTADL="http://www.example.com:100/EG800Q_FOTA_PACKAGE.par",1,50
Thanks in advance!
Please provide your detailed firmware version
AT+QGMR
Hi @herbert.pan-Q
This is the version returned by QGMR command “EG916QGLLGR01A05M04_01.001.01.001”
Thank you
I have sent the link to your email,pls check and try again
thank you Herbert, i got your firmware link now
