Hi, i am using EG916Q-GL module.
I am based in Serbia, the module can detect local network, but fails to connect to them.
I believe I am using an older firmware version of the module, I would like to request the latest, and then try again.
at+qgmr
EG916QGLLGR01A03M04_01.001.01.001
AT+CIMI
901405101215756
at+cpin?
+CPIN: READY
at+cops?
+COPS: 0
AT+CSQ
+CSQ: 23,99
at+cops=?
+COPS: (2,“”,“”,“22003”,7),(0,“”,“”,“22001”,7),(0,“”,“”,“22005”,7),(0-4),(0-2)
Hi
Please first check if the SIM card is valid and if there are any outstanding fees.
If there are no issues with the SIM card, I will send the firmware to your email
Hi.
Thank you for your reply, I have checked the device with another 1nce SIM card that I know is working and it still doesn’t connect to the network. I tried a local SIM card, and with that card the module has no problem connecting to the network. But with the 1nce SIM card it just won’t. I have used 1nce SIM cards with your other modules, such as M95, M95-R, EG915U-EU, BG95-M3 and had no problem connecting to the network.
Also, I have no access to the USB-DB pins, so i will need to do a DFOTA update from EG916QGLLGR01A03M04_01.001.01.001 to EG916QGLLGR01A05M04_01.002.01.002 if possible
