I’m developing an application based on mqtts using eg916gl module. It works fine, but I get error 5 at OPEN command, when I use “ignorelocaltime” set to 0
Can you help me?
Hi ale,
Encountering error 5 during the AT+QMTOPEN command specifically indicates a network connection error.
As per your observation where this error occurs when you set “ignorelocaltime” to 0, it strongly suggests a failure in the SSL certificate validity check.
When ignorelocaltime is set to 0, the module is required to verify the server’s certificate against its own local real-time clock (RTC)
SSL certificates contain “Not Before” and “Not After” timestamps.
If the module’s local time is earlier than the “Not Before” time or later than the “Not After” time , the certificate is considered invalid, and the SSL handshake will fail with a network connection error.
To resolve this, you must ensure the module has the correct current time before attempting to open the MQTTS connection:
- Manual Time Setting: Use the command below to manually set the module’s clock to the current date and time.
AT+CCLK command
Example: AT+CCLK=“24/05/20,10:00:00+08” (sets the time to 20 May 2024, 10:00:00).
- Network Time Synchronization (NITZ): Enable automatic time zone and time updates from the cellular network using:
AT+CTZU=1
Note that this command takes effect after a reboot and depends on network support.
- NTP Synchronization: Use the command below to synchronize the module’s local time with an external NTP server.
AT+QNTP
Example: AT+QNTP=1,“pool.ntp.org”,123,1 (synchronizes context 1 with the specified server and automatically sets the local time).
- Query Network Time: You can also manually trigger a query for the latest network-synchronized time using:
AT+QLTS
Thank you and have a nice day!
Thank you so much AmarRaaj,
but I already use command AT+CTZU=1
So, when I retrieve module date/time with AT+CCLK, I can observe a correct internal date/time for the module. And more, I use module date/time to create “time from epoch” to emebed into payload, and it works fine. So, what do you suggest? Is the issue related to server certificate? Or in client/key certificate?
Hello AmarRaaj,
I’m sure validity of server and client certificate is ok. Are you sure this fetaure in module EG916Q-GL is ok?
Is it possible to know if there is an issue about this feature on EG916Q-gl?
