I have a USB communication problem with the EG915 module, it is connected, I see the USB ports but I am unable to launch the AT commands with minicom on any of the 7 USB ports
dmesg
[ 2.108956] usb 1-1.3: new high-speed USB device number 3 using ci_hdrc
[ 2.240226] usb 1-1.3: config 1 interface 0 altsetting 0 endpoint 0x81 has an invalid bInterval 32, changing to 9
[ 2.255356] option 1-1.3:1.0: GSM modem (1-port) converter detected
[ 2.263131] option 1-1.3:1.1: GSM modem (1-port) converter detected
[ 2.270905] option 1-1.3:1.2: GSM modem (1-port) converter detected
[ 2.277691] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
[ 2.286682] option 1-1.3:1.3: GSM modem (1-port) converter detected
[ 2.293428] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
[ 2.301897] option 1-1.3:1.4: GSM modem (1-port) converter detected
[ 2.307751] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB4
[ 2.315084] option 1-1.3:1.5: GSM modem (1-port) converter detected
[ 2.321017] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB5
[ 2.328323] option 1-1.3:1.6: GSM modem (1-port) converter detected
[ 2.334312] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB6
[ 2.341702] option 1-1.3:1.7: GSM modem (1-port) converter detected
[ 2.347560] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB7
[ 2.355077] option 1-1.3:1.8: GSM modem (1-port) converter detected
[ 2.361054] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB8
and
lsusb -v
Bus 001 Device 003: ID 2c7c:0901
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2c7c
idProduct 0x0901
bcdDevice 3.18
iManufacturer 1 Android
iProduct 2 Android
iSerial 3
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 263
bNumInterfaces 9
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 400mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2
bFunctionSubClass 6
bFunctionProtocol 0
iFunction 4 CDC Ethernet Control Modle (ECM)
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2
bInterfaceSubClass 6
bInterfaceProtocol 0
iInterface 6 CDC ECM
CDC Header:
bcdCDC 1.10
CDC Union:
bMasterInterface 0
bSlaveInterface 1
CDC Ethernet:
iMacAddress 7 024bb3b9ebe5
bmEthernetStatistics 0x00000000
wMaxSegmentSize 1514
wNumberMCFilters 0x0000
bNumberPowerFilters 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 32
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceClass 10
bInterfaceSubClass 0
iInterface 0
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 2
bInterfaceClass 10
iInterface 5 CDC Ethernet Data
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255
iInterface 8 Mobile Generic Serial
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 6
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x88 EP 8 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 7
bAlternateSetting 0
bNumEndpoints 3
bInterfaceClass 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x8a EP 10 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x07 EP 7 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x89 EP 9 IN
bmAttributes 3
Synch Type None
Usage Type Data
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 8
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255
bLength 7
bDescriptorType 5
bEndpointAddress 0x8b EP 11 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x08 EP 8 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
can’t get debug descriptor: Resource temporarily unavailable
Thank you
R.
