I have a few questions about the electrical characteristics of the PWRKEY pin and the UART pins of the EG915U-EU module. Unfortunately, the hardware design document (v1.1) leaves a few questions unanswered.
The PWRKEY pin is an input (DI, as called in the hardware design document), but probably has a pull-up to VBAT. How big is this resistance to VBAT signal or what current do I have to sink to pull the pin to 0V?
The hardware design document says: “When using AP_READY, MAIN_DTR, and MAIN_RI (pins 19, 30, and 39), please note that these pins will have a period of variable level state (not controllable by software) after the module is powered on: at high level (3.0 V) for 2 s and then at low level (0 V) for 1.2 s before they can be configured as 1.8 V input or output.” …
What does that mean? The document also states that the UART pins belong to the 1.8V voltage domain. But is there still 3V on these pins for 2 seconds after power up (is that really 3V or simply VBAT)? What impedance do these pins have at 3V, is this a pull-up to VBAT, what currents should I expect when the 3V is discharged via the clamping diodes of my 1.8V microprocessor?
Thanks in advance,
Patrick
