EG915Q-AF Modem Logging
Hi Team,
When I connect EG915Q-AF module to my windows machine, it exposes three ports, AT, DIAG and NMEA. I have below questions:
Why it does not exposes DM port for logging?
Should we use DIAG port for logging?
What is difference between DIAG port and DM port? I have Quectel BG95M3 which has DM port not DIAG port.
Is it any differnce in the chipsets used by BG95M3 vs EG915Q-AF ?
Is there any debug AT command which needs to be enabled before starting to capture logs?
What are the default USB port settings for capturing the modem logs?
Thank you.
Hi there,
EG915Q uses different chipset compared to BG95M3 module.
For EG915Q log capturing, you can use EPAT Tool and DIAG port to collect the log.
I will send a follow up email together with the EPAT Tool guideline to your email regarding this query.
