I am seeing duplicated incoming SMS on an EG915N-EU and would like to understand whether this is expected behaviour or a known issue.
Module: Quectel EG915N
Firmware: EG915NEUAGR03A09M16
-– Problem —
A single SMS sent to the module results in TWO stored messages. Sender, text and service centre timestamp (SCTS) are identical, but they are stored as two separate records: one in SM and one in ME.
-– Steps to reproduce —
- Module restored to factory defaults.
- Only AT+CMGF=1 issued. No CNMI, CSMP or CPMS configuration at all.
- One single SMS sent to the module from another phone.
-– Observed behaviour —
Two URCs are received for one incoming message:
+CMTI: “ME”,0
+CMTI: “ME”,0
Listing with the default active storage (SM):
AT+CMGL=“ALL”
+CMGL: 0,“REC UNREAD”,“+9054xxxxxxx”,“26/09/01,13:43:10+12”
Test1
AT+CPMS=“SM”,“SM”,“SM”
+CPMS: 1,35,1,35,1,180
AT+CMGL=“ALL”
+CMGL: 0,“REC READ”,“+9054xxxxxxx”,“26/09/01,13:43:10+12”
Test1
Switching to ME:
AT+CPMS=“ME”,“ME”,“ME”
+CPMS: 1,180,1,180,1,180
AT+CMGL=“ALL”
Test1
So there is one copy in SM and one copy in ME, both with the same SCTS (26/09/01,13:43:10+12).
The read status differs between the two copies: listing SM marked its copy as REC READ, while the ME copy was still REC UNREAD afterwards. This confirms these are two distinct stored records, not the same record listed twice.
I also noticed that AT+CPMS=“SM”,“SM”,“SM” returns 1,180 for the third pair, so mem3 appears to stay on ME and does not accept “SM”.
-– Questions —
Do the two +CMTI URCs mean the network actually delivered the SMS-DELIVER twice, or is this a firmware storage behaviour that writes a single delivery into both SM and ME?
With factory default settings on this firmware, is AT+CNMA acknowledgement required? What are the default CSMS and CNMI values on EG915N, and can a missing CNMA cause the network to re-deliver?
Could this be related to SMS over IMS and CS/SGs delivery running in parallel? Is there a recommended AT+QCFG setting for SMS format or IMS on this module?
Why does mem3 not accept “SM” in AT+CPMS? Is mem3 restricted to ME on EG915N?
Is there a newer firmware release that addresses duplicate SMS delivery or storage behaviour?
Any guidance would be appreciated. I can provide raw PDU output (AT+CMGF=0, AT+CMGL=4) of both records or a full AT log if that helps.
Thank you.
