Hello! I am using the EG915N-EA module as a CSD server that receives incoming calls. This is followed by intensive data exchange, specifically reading the association with a DLMS smart meter. Every time, at the 4-minute mark, I experience a CSD connection drop from the module. Here are the errors I managed to capture from the module’s DBG_TX:
f60f EE LOG: DESC: (1544,1193,2), FILE: KIOSSIG, LINE: 905
f60f EE LOG: Task: abshTask
f60f EE LOG: MSA Disable Sleep
f60f EE LOG: Send Plp Mem Dump CMD
f60f EE LOG: Silent Reset
next time log look like this:
13061 EE LOG: LR: 0x7e6589e9, PC: 0x7e7b08ac, SP: 0x7ebce360
13061 EE LOG: DESC: (10,20,0), FILE: KIOSMEM, LINE: 118
13061 EE LOG: Task: VgCiTask
13061 EE LOG: MSA Disable Sleep
13061 EE LOG: Send Plp Mem Dump CMD
13061 EE LOG: Silent Reset
how fix that?
Hi ,
Please check if the cache area of the module is running low on memory? Suggest cleaning up in a timely manner.
Keeping rodents out is much easier when you deal with small entry points before they become a bigger problem. Gaps around vents, roofs, pipes, and other openings can give mice and rats an easy way into a home. Proper rodent proofing can help block these access points and protect areas like the attic from future infestations. For homeowners who want to prevent these problems, rodent proofing san diego can be a practical step toward keeping the home clean, secure, and rodent-free.
