Hi Quectel team,
I have QuecPython EVB with EG912UGL_AA module.
I am evaluating the NorFlash connected on board as SPI6 interface to store the prepack files.
QFlashv7.4 shows the Errcode :262 while writing Prepack file.
Please find following for your reference to suggest the solution to resolve the error
QuecOPen version: LTE01R03A06
following code i entered in target config
#SPI6 NAND Flash
CONFIG_QUEC_PROJECT_FEATURE_SPI6_NAND_FLASH=n
CONFIG_QUEC_PROJECT_FEATURE_FS_NAND_FLASH=n
#SPI4 NAND Flash
CONFIG_QUEC_PROJECT_FEATURE_SPI_NAND_FLASH=n
#Boot SPI6
CONFIG_QUEC_PROJECT_FEATURE_BOOT_SPI6_NAND=n
#SPI6 NOR FS
CONFIG_QUEC_PROJECT_FEATURE_SPI6_EXT_NOR_SFFS=y
CONFIG_QUEC_PROJECT_FEATURE_SPI4_EXT_NOR=n
CONFIG_QUEC_PROJECT_FEATURE_SPI_NOR_FLASH=y
#BOOT SPI6 NOR
CONFIG_QUEC_PROJECT_FEATURE_BOOT_SPI6_EXTNSFFS=y
following code in quec_spi_nor_flash_prop.c
#ifndef DISABLE_W25Q32JW_FW
// W25Q32JWUUIQ
.mid = 0x1660ef, // W25Q32JW
.capacity = 0x400000,
.mode = QUEC_NOR_FLASH_MODE_16BIT,
.mount_start_addr = 0x0000000,
.mount_size = 0x400000,
.pb_size = 0x200,
.eb_size = 0x1000,
#endif
Anticipate your earliest guidance. Thank you
