EG912U-GL Main UART baud rate change from USB
I’m trying to change the main uart baud rate executing a command from the USB without luck.
AT+CBAUD=230400
AT+CBAUD?
+CBAUD: 115200
Is it possible to do it? Executing this command from the main uart does actually work but I need to be able to do it from the USB.
Modem version
AT+QGMR
EG912UGLAAR03A11M08_01.200.01.200
Thank you
pls run and try
AT+IPR=230400;&W
Using the USB AT Port gives an error
AT+IPR=230400
+CME ERROR: 3
From the main UART it works, but I need to do it through the USB
Thank you
The baud rate of the USB AT port is adaptive and does not require configuration.
