Eg912u-gl latest firmware
Hi there,
Please send me latest firmware for eg912u-gl.
[2025-02-21 16:45:21:690_R:] OK
[2025-02-21 16:45:21:704_S:] ATI
[2025-02-21 16:45:21:712_R:] ATI
[2025-02-21 16:45:21:712_R:] Quectel
[2025-02-21 16:45:21:712_R:] EG912U
[2025-02-21 16:45:21:712_R:] Revision: EG912UGLAAR03A06M08
By the way i did not this process before. Please if you have a documentation for firmware upgrade please send it too me…
I installed QFlash v7.3.
If I need special driver for my custom modul, i can take a link the driver..
My mail is fatihbasaris@gmail.com.
Best regards..
Hi Sir
I will check and reply via email. Thx for your understanding
Can i get the last firmware version please.
Thank you
email: sami.abada@zero-carbon-emission.com
AT+QGMR
EG912UGLAAR03A12M08_01.200.01.200
Hi,@ZCE_DEV
The lastest firmware have already sent to you via email,pls check.
Hi @leon.bao
Thank you for providing the firmware for the PH-7 module. I am currently working with the PH-7 (C4-P02) Core Board based on the EG912U GL. However, when I connect the board via USB to my PC, no serial port is detected. I assume that a serial port must appear in order to properly flash the firmware using QFlash_V7.4, yet I have not found any information addressing this issue.
Could you please advise on the proper steps to detect a serial port and subsequently flash the firmware? Any detailed guidance or references to additional documentation would be greatly appreciated.
Thank you for your assistance.
Hi,@ZCE_DEV
I’ve already sent you the USB driver. After installation, please check whether the corresponding serial port can be recognized. You can use the AT port to upgrade the firmware through the QFLASH tool.
Hi again..
Thank you
email:fatihbasaris@gmail.com
14:33:22.409 → AT+QGMR
14:33:22.409 → EG912UGLAAR03A15M08_01.200.01.200
@fth_41
I will check and reply if i get the firmware version.
BTW, what is the issue in your side currently? Much appreciation
