EG912U-GL and eSIM(ST4SIM_300M)
I am reaching out to inquire about the compatibility and practical usage of eSIM with the EG912U-GL module.
I am currently developing an IoT device based on the EG912U-GL. However, I need to implement eSIM functionality, and I would like to clearly confirm whether this module supports eSIM. After reviewing the hardware design datasheet, I was unable to find any reference to eSIM support.
If eSIM usage is possible, I would also like to understand which type of eSIM should be used.
At present, I am designing the device using the ST4SIM_300M, as it supports remote profile provisioning over LTE or Wi-Fi. This requires the eSIM to support a bootstrap profile, which I understand is a key feature of the ST4SIM_300M.
Given this, I would like to confirm whether the EG912U-GL supports LPA (Local Profile Assistant) functionality necessary for managing eSIM profiles.
I would greatly appreciate a clear and prompt response from anyone with relevant experience or knowledge.
Thank you.
Hi there,
EG912U-GL can support Esim Feature up untill SGP.32 . I believe this ST4SIM_300M is supporting SGP.32 .
Furthermore, EG912U-GL also supports LPA (Local Profile Assistant) functionality necessary for managing eSIM profiles.
