EG912 Local IP change
I am using the EG912 LTE module in an embedded system with more network interfaces. In some cases, there is a need for IP change to avoid conflict. The default IP assigned by the embedded DHCP server in CDC mode is:
192.168.43.100 (with GW 192.168.43.1)
Can you please provide a way (e.g. AT command) how to change it?
Thanks!
Hi
You can refer to the command to modify
AT+QICSGP=[,<context_
type>,[,,)[,]]]
Quectel_EC200U&EG915U_Series_TCP(IP)_Application_Note_V1.1.pdf (462.7 KB)
I am sorry, but I do not see any field where I can specify a local IP address via the AT+QICSGP command. There are just APN, NAME, PASSWORD,…
Can you please provide an example of how to change the local RNDIS/ECM adapter IP address?
Thank you.
