I am experiencing some issues with the USB interface for the EG91. The goal is to interface it with an STM32H7, however the USB connection seems to be unstable. It also appears to be unstable when connecting the modem to my windows PC.
Could I please have the latest firmware for the EG91 (I am currently using EG91EXGAR08A05M1G). I understand there are some changes to the modems USB configuration in the firmware which may fix the issue, is that correct?
That is correct yes, I can see the COM ports repeatedly connecting and disconnecting in the device manages. STM also reports that the modem repeatedly connects and disconnects too
I have received and installed the new drivers, thank you. There is still some disconnection events but much less than before. Are there any conditions (such as noise on the Vbus pin) that would cause the USB peripheral to reset but not the modem as a module?
