EG91 firmware incompatity
We are having problems with an EG91 modem with EG91EXGAR10A03M1G_01.003.01.003 firmware revision and a 5.10.192 kernel. The kernel is no creating the corresponding USB devices. Also we have an other EG91 that have came with the EG91EXGAR08A16M1G_20.200.20.200 firmware revision and this is working correctly.
We will need to update the firmware version of the non working EG91 modem to EG91EXGAR08A16M1G_20.200.20.200 version to solve this. Could you provide us the fimware and tool to make the update in a linux ARM64 equip please?
Note: I´ve obtained the firmware with the response of AT+QGMR.
My email is iker.landaluce@seidor.com
Best regards.
I can send you the EG91EXGAR08A17M1G_20.200.20.200.
But I don’t understand what it means? Could you show me?
Please do not flash it. Please provide the IMEI of the modem.
I didn’t find the firmwware 91EXGAR10A03M1G and I am wondering that you flash the mdoem with an incorrect firmware.
Hello Bean. I attach you some screenshots of 2 equips with same OS, the only difference is the modem firmware. On left side you have the screenshots corresponding to the equip with EG91EXGAR08A16M1G_20.200.20.200 firmware, witch is working correctly, on the rigth side you have the NO OK working modem.
It does not seems to be bug. The bcdDevice is not necessary.
You can show the
lsusb -t
cat /sys/kernel/debug/usb/devices
What we care about is the USB configuration descriptors 、interface descriptors and endpoint descriptors.
Here you have:
This is the result for the non working LTE (with 91EXGAR10A03M1G FW)
root@DS2023121272100038:~# lsusb -t
/: Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
/: Bus 04.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Wireless, Driver=btusb, 480M
|__ Port 1: Dev 2, If 1, Class=Wireless, Driver=btusb, 480M
|__ Port 1: Dev 2, If 2, Class=Vendor Specific Class, Driver=rtl8821cu, 480M
/: Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
|__ Port 1: Dev 6, If 3, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 6, If 1, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 6, If 4, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 6, If 2, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 6, If 0, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 2: Dev 3, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
|__ Port 3: Dev 4, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=dwc2/1p, 480M
root@DS2023121272100038:~# cat /sys/kernel/debug/usb/devices
T: Bus=01 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 0/800 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0002 Rev= 5.10
S: Manufacturer=Linux 5.10.198 dwc2_hsotg
S: Product=DWC OTG Controller
S: SerialNumber=ff580000.usb
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr= 0mA
I:* If#= 0 Alt= 0 #EPs= 1 Cls=09(hub ) Sub=00 Prot=00 Driver=hub
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=256ms
T: Bus=02 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
B: Alloc= 4/800 us ( 1%), #Int= 2, #Iso= 0
D: Ver= 2.00 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
S: Manufacturer=Linux 5.10.198 ehci_hcd
S: Product=EHCI Host Controller
S: SerialNumber=ff5c0000.usb
T: Bus=02 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 4
P: Vendor=05e3 ProdID=0608 Rev=85.38
S: Product=USB2.0 Hub
C:* #Ifs= 1 Cfg#= 1 Atr=e0 MxPwr=100mA
E: Ad=81(I) Atr=03(Int.) MxPS= 1 Ivl=256ms
T: Bus=02 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 6 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=2c7c ProdID=0191 Rev= 0.00
S: Manufacturer=Quectel
S: Product=EG91-EX
S: SerialNumber=1234567890ABCDEF
C:* #Ifs= 5 Cfg#= 1 Atr=e0 MxPwr=500mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=option
E: Ad=82(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=83(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=84(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=fe Prot=ff Driver=(none)
E: Ad=85(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=86(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
I:* If#= 4 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=87(I) Atr=03(Int.) MxPS= 64 Ivl=2ms
E: Ad=88(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=02 Lev=02 Prnt=02 Port=01 Cnt=02 Dev#= 3 Spd=12 MxCh= 0
D: Ver= 1.10 Cls=ff(vend.) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=1a86 ProdID=7523 Rev= 2.64
S: Product=USB Serial
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr= 98mA
I:* If#= 0 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=01 Prot=02 Driver=ch341
E: Ad=82(I) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 32 Ivl=0ms
E: Ad=81(I) Atr=03(Int.) MxPS= 8 Ivl=1ms
T: Bus=02 Lev=02 Prnt=02 Port=02 Cnt=03 Dev#= 4 Spd=12 MxCh= 0
T: Bus=03 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=12 MxCh= 1
B: Alloc= 0/900 us ( 0%), #Int= 0, #Iso= 0
D: Ver= 1.10 Cls=09(hub ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=1d6b ProdID=0001 Rev= 5.10
S: Manufacturer=Linux 5.10.198 ohci_hcd
S: Product=Generic Platform OHCI controller
S: SerialNumber=ff5d0000.usb
E: Ad=81(I) Atr=03(Int.) MxPS= 2 Ivl=255ms
T: Bus=04 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=480 MxCh= 1
S: Manufacturer=Linux 5.10.198 xhci-hcd
S: Product=xHCI Host Controller
S: SerialNumber=xhci-hcd.0.auto
T: Bus=04 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=ef(misc ) Sub=02 Prot=01 MxPS=64 #Cfgs= 1
P: Vendor=0bda ProdID=c820 Rev= 2.00
S: Manufacturer=Realtek
S: Product=802.11ac NIC
C:* #Ifs= 3 Cfg#= 1 Atr=a0 MxPwr=500mA
A: FirstIf#= 0 IfCount= 2 Cls=e0(wlcon) Sub=01 Prot=01
I:* If#= 0 Alt= 0 #EPs= 3 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=81(I) Atr=03(Int.) MxPS= 16 Ivl=1ms
I:* If#= 1 Alt= 0 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 0 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 0 Ivl=1ms
I: If#= 1 Alt= 1 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 9 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 9 Ivl=1ms
I: If#= 1 Alt= 2 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 17 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 17 Ivl=1ms
I: If#= 1 Alt= 3 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 25 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 25 Ivl=1ms
I: If#= 1 Alt= 4 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 33 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 33 Ivl=1ms
I: If#= 1 Alt= 5 #EPs= 2 Cls=e0(wlcon) Sub=01 Prot=01 Driver=btusb
E: Ad=03(O) Atr=01(Isoc) MxPS= 49 Ivl=1ms
E: Ad=83(I) Atr=01(Isoc) MxPS= 49 Ivl=1ms
I:* If#= 2 Alt= 0 #EPs= 5 Cls=ff(vend.) Sub=ff Prot=ff Driver=rtl8821cu
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=87(I) Atr=03(Int.) MxPS= 64 Ivl=500us
E: Ad=08(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
T: Bus=05 Lev=00 Prnt=00 Port=00 Cnt=00 Dev#= 1 Spd=5000 MxCh= 1
D: Ver= 3.00 Cls=09(hub ) Sub=00 Prot=03 MxPS= 9 #Cfgs= 1
P: Vendor=1d6b ProdID=0003 Rev= 5.10
Here you have the other outout with the working firmware (EG91EXGAR08A16M1G):
root@DS2023121272100108:~# lsusb -t
|__ Port 1: Dev 37, If 3, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 37, If 1, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 37, If 4, Class=Vendor Specific Class, Driver=, 480M
|__ Port 1: Dev 37, If 2, Class=Vendor Specific Class, Driver=option, 480M
|__ Port 1: Dev 37, If 0, Class=Vendor Specific Class, Driver=option, 480M
root@DS2023121272100108:~# cat /sys/kernel/debug/usb/devices
B: Alloc= 4/800 us ( 1%), #Int= 3, #Iso= 0
T: Bus=02 Lev=02 Prnt=02 Port=00 Cnt=01 Dev#= 37 Spd=480 MxCh= 0
P: Vendor=2c7c ProdID=0191 Rev= 3.18
S: Product=EG91-EX
S: SerialNumber=0123456789ABCDEF
C:* #Ifs= 5 Cfg#= 1 Atr=a0 MxPwr=500mA
I:* If#= 1 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=83(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
I:* If#= 2 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=85(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
I:* If#= 3 Alt= 0 #EPs= 3 Cls=ff(vend.) Sub=00 Prot=00 Driver=option
E: Ad=87(I) Atr=03(Int.) MxPS= 10 Ivl=32ms
E: Ad=89(I) Atr=03(Int.) MxPS= 8 Ivl=32ms
OK the USB interface class descriptor is not the same.
Is it Ubuntu? could you send me the option.c (which should be in kdir/drivers/usb/serial/option.c)
What’s the Linux kernel version.
I think you can modfiy the option.c to make both work.
Hello Bean:
The kernel version is 5.10.198, provided by Rockchip.
If you give an idea of what should I modify I can make those modifications and recompile the kernel again. Here is my original file.
option.c (137.7 KB)
I´ve also compiled a kernel with the latest published option.c for 5.10.X, but the problem persists:
option.c « serial « usb « drivers - kernel/git/stable/linux.git - Linux kernel stable tree
{ USB_DEVICE(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EG91),
 .driver_info = RSVD(4) },
Please try this.
option.c (137.8 KB)
The original is
	{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EG91, 0xff, 0xff, 0xff),
	  .driver_info = NUMEP2 },
	{ USB_DEVICE_AND_INTERFACE_INFO(QUECTEL_VENDOR_ID, QUECTEL_PRODUCT_EG91, 0xff, 0, 0) },
It means that it only will match the USB interface with
USB class is 0xFF , subclass is 0xFF, proto is 0xFF and there is only 2 endpoints.
And the follow means that it can only choose the USB class is 0xFF, and the subclass & proto is 0x0.
Hello Bean.
I´ve recompiled the kernel overriding my option.c by the file you provide and seems now is working. Now my system detects the modem with the EG91EXGAR08A16M1G_20.200.20.200 firmware and is able to stand up a connection with that LTE module. Also is working with the EG91EXGAR08A16M1G_20.200.20.200 firmware.
Thanks for your support
Great!
And yes the two firmware there is a difference in USB configuration.
Hi Bean,
I am also experiencing some issues with the USB interface for the EG91. The goal is to interface it with an STM32H7, however the USB connection seems to be unstable. It also appears to be unstable when connecting the modem to my windows PC.
Could I please have the latest firmware for the EG91 (I am currently using EG91EXGAR08A05M1G). I understand there are some changes to the modems USB configuration in the firmware, is that correct?
Thanks,
Andy
