Hi Eliacim,
Thanks for the update. The results you shared point to a signal (RF) issue.
The key output is:
AT+CSQ
+CSQ: 99,99
99,99 means the module cannot detect any cellular signal. Without signal, the module cannot register on the network, which explains the CREG: 0,0 and CREG: 0,4 results.
Your other settings look correct:
CFUN: 1 → RF is enabled
COPS: 0 → Automatic network selection
Roaming is enabled
Since the module registered once before, the SIM and configuration are likely OK. This strongly suggests a hardware or environment issue.
Please check the following:
-Ensure the cellular antenna is properly connected (reseat it if needed).
-Try a different known-good antenna, if possible.
-Test in a location with good cellular coverage (near a window or outdoors).
Also check Band / RAT configuration:
If bands or RATs were previously restricted, registration may fail.
AT+QCFG=“nwscanmode”,0,1
AT+QCFG=“band”
Make sure the module is allowed to scan all supported RATs and bands used by roaming networks in Mexico.
For additional diagnostics, you may also run:
AT+QCSQ
AT+QENG=“servingcell”
For testing, you may also try using a local SIM card (non-roaming) to verify whether this is a hardware-related issue.
Have a great day!
Best Regards,
Ananthan
