I would need suitable Win10 drivers for my EG800Q-EU on the EVK.
EG800Q
Revision: EG800QEULCR01A07M04
USB\VID_2C7C&PID_6007&REV_0200&MI_04
USB\VID_2C7C&PID_6007&REV_0200&MI_03
USB\VID_2C7C&PID_6007&REV_0200&MI_02
USB\VID_2C7C&PID_6007&REV_0200&MI_01
USB\VID_2C7C&PID_6007&REV_0200&MI_00
Thanks!
Please set the EG800Q to RNDIS mode and try the driver I sent.
AT+QCFG=“usbnet”,3
Thank you for providing the NDIS driver set.
I would need the USB serial/DIAG/GNSS port drivers for the above mentioned FW and USB dveice IDs.
Would it be possible to get them as well?
Thanks and greetings to Hefei.
If you have set the EG800Q to RNDIS mode already, and have installed the driver, there should be DIAG exists.
RNDIS is not the same with NDIS. EG800Q only support ECM and RNDIS, and not support NDIS.
Unfortunately the drivers are not fitting to my FW : EG800QEULCR01A07M04
Would it be possible to maybe get a FW update for that I can finally use the module?
Thank you
Do you have an Ubuntu Machine?
Please show the devicemananager.
nope - no Ubuntu - Win10
As written in the initial post, these are the USB IDs:
In your drivers .inf files nothing is fitting to VID_2C7C&PID_6007
May you prvide me a FW update for the EG800-Q-EU eval board?
