EG800Q-EU roaming problem
Hi
The EG800Q-EU modem won’t work when roaming abroad. I have a Polish SIM card (PLAY, PLUS), and it works fine in Poland. When I moved to the Czech Republic or Austria, it wouldn’t connect to the network. The same SIM cards used in my phone connect without a problem. I also bought a Czech O2 SIM card, and it won’t connect to the network in Poland either. What’s the problem?
EG800Q-EU
Revision: EG800QEULCR01A08M04
Regards Tom
Nobody has this problem?
Did you check with AT+QCFG="roamservice" ?
Yes, I set it, and only one I get CREG 5, but about 2-3 seconds later I get CREG 2. It looked like the modem logged in for a moment and then the network kicked it out.
It looked like the modem logged in for a moment and then the network kicked it out. It couldn’t be repeated.
Dear @wilkxt ,
Good day,
On this particular issue , can you provide us the log files for futher analysis? and are you using only one module or several modules that face the issue?
Thank You and Have a great Day!
the problem is with APN, I get Czech Republic card and it run ok in Poland, CREG 5. But I not testen Polish sim card in Czech republick
