I’m working on connecting an NXP RT1060 with the EG800Q over USB. I have a sample from NXP that’s designed for the EC200A. I’ve been able to communicate with the EG800Q over both serial and USB from my laptop, and I’ve run AT+QCFG=“usbnet”,3 to put the EG800Q in RNDIS mode.
However, when I run the sample code it fails to detect the RNDIS interface over USB. The sample expects an interface that’s Base Class E0h, Subclass 01h, Protocol 03h, but the EG800Q seems to only advertise the CDC 0Ah and Communications and CDC Control 02h interfaces. Is there any other AT command I need to send to the EG800Q to make it advertise RNDIS support?
I’ve tried running AT+QNETDEVCTL=1,1,1, which seems to run successfully (although I can’t find it in any of the AT command overviews for the EG800Q), and AT+QNETDEVSTATUS?, which fails (even thought it’s listed in the overview of AT commands).
Thanks,
Daniel
This is the output from running ATI:
ATI
EG800G
Revision: EG800GEULDR01A09M04
and ATI+QCFG=“usbnet”:
AT+QCFG=“usbnet”
+QCFG: “usbnet”,3
Is there a newer FW for the EG800Q that I need for it to actually go into RNDIS mode? Because from reading the USB spec it seems that the CDC interface it advertises (class=02h, subclass=02h, protocol=00h) is used for ECM.
For reference, when I use lsusb on the device I get the following (which matches what I see the NXP sample code finds):
daniel@daniel-XPS-15-9530:~$ lsusb -D /dev/bus/usb/001/025
Device: ID 04e2:1411 Exar Corp. XR21B1411
Couldn't open device, some information will be missing
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 239 Miscellaneous Device
bDeviceSubClass 2
bDeviceProtocol 1 Interface Association
bMaxPacketSize0 64
idVendor 0x04e2 Exar Corp.
idProduct 0x1411
bcdDevice 0.01
iManufacturer 1 Exar Corp.
iProduct 2 XR21B1411
iSerial 3 R7822020661
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 0x004b
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 0
bmAttributes 0xa0
(Bus Powered)
Remote Wakeup
MaxPower 100mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 2 Communications
bFunctionSubClass 2 Abstract (modem)
bFunctionProtocol 0
iFunction 0
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 2 Communications
bInterfaceSubClass 2 Abstract (modem)
bInterfaceProtocol 1 AT-commands (v.25ter)
iInterface 0
CDC Header:
bcdCDC 1.10
CDC ACM:
bmCapabilities 0x06
sends break
line coding and serial state
CDC Union:
bMasterInterface 0
bSlaveInterface 1
CDC Call Management:
bmCapabilities 0x01
call management
bDataInterface 1
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x85 EP 5 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0040 1x 64 bytes
bInterval 2
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 10 CDC Data
bInterfaceSubClass 0
bInterfaceProtocol 0
iInterface 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x01 EP 1 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x81 EP 1 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
So, does the EG800Q not support RNDIS?
We discovered that most of the interfaces from the EG800 aren’t exposed through the micro-USB on the dev-board the EG800 is on, but rather through the micro-USB on the UMTS<E_EVB (J801) which the EG800’s dev-board is connected to. In the photo that’s the micro-USB at the bottom. On my machine the USB device is listed as Quectel Wireless Solutions Co., Ltd. Android, and doing lsusb on it shows the RNDIS interface:
daniel@daniel-XPS-15-9530:~$ lsusb -D /dev/bus/usb/003/018
Device: ID 2c7c:0904 Quectel Wireless Solutions Co., Ltd. Android
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x2c7c Quectel Wireless Solutions Co., Ltd.
idProduct 0x0904
bcdDevice 3.18
iManufacturer 1 Android
iProduct 2 Android
iSerial 3
bLength 9
bDescriptorType 2
wTotalLength 0x00be
bNumInterfaces 7
iConfiguration 0
bmAttributes 0xe0
Self Powered
Remote Wakeup
MaxPower 400mA
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 224 Wireless
bFunctionSubClass 1 Radio Frequency
bFunctionProtocol 3 RNDIS
iFunction 6
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 224 Wireless
bInterfaceSubClass 1 Radio Frequency
bInterfaceProtocol 3 RNDIS
iInterface 4
** UNRECOGNIZED: 05 24 00 10 01
** UNRECOGNIZED: 05 24 01 00 01
** UNRECOGNIZED: 04 24 02 00
** UNRECOGNIZED: 05 24 06 00 01
bLength 7
bDescriptorType 5
bEndpointAddress 0x82 EP 2 IN
bmAttributes 3
Synch Type None
Usage Type Data
wMaxPacketSize 0x0008 1x 8 bytes
bInterval 16
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 2
iInterface 5
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
wMaxPacketSize 0x0200 1x 512 bytes
bInterval 0
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 2
bAlternateSetting 0
bNumEndpoints 2
bInterfaceClass 255 Vendor Specific Class
iInterface 7
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x02 EP 2 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 3
bAlternateSetting 0
bNumEndpoints 2
iInterface 7
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x03 EP 3 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 4
bAlternateSetting 0
bNumEndpoints 2
iInterface 7
bLength 7
bDescriptorType 5
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x04 EP 4 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 5
bAlternateSetting 0
bNumEndpoints 2
iInterface 7
bLength 7
bDescriptorType 5
bEndpointAddress 0x86 EP 6 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x05 EP 5 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 9
bDescriptorType 4
bInterfaceNumber 7
bAlternateSetting 0
bNumEndpoints 2
iInterface 7
bLength 7
bDescriptorType 5
bEndpointAddress 0x87 EP 7 IN
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
bLength 7
bDescriptorType 5
bEndpointAddress 0x06 EP 6 OUT
bmAttributes 2
Transfer Type Bulk
Synch Type None
Usage Type Data
bInterval 0
Edit: powering the UMT<E EVB with external 5V, and then connecting the EVB to the NXP using the J801 micro-USB port, the NXP detects the RNDIS interface.
