I’m working with the EG800Q (EG800QEULCR01A09M04), and trying to read a concatenated SMS. Here’s my sequence of commands:
# Enable TEXT mode
AT+CMGF=1
AT+CMGR=<index>
<TEXT data>
AT+QCMGR=<index>
<PDU data>
I’ve already enabled TEXT mode, and reading out a message using AT+CMGR works fine, and it returns text data. However, when using AT+QCMGR it returns PDU data (starts with 0791 which I believe is the start of a SMSC header), even though the AT command manual (v1.0) states the command only works in TEXT mode:
Similar to AT+QCMGS, AT+QCMGR is only used in text mode (AT+CMGF=1).
Testing the command using AT+QCMGR=? returns OK, so that works fine.
I’m wondering if there’s a bug in the FW of the module, or if there’s something I’m missing to make it return data in TEXT mode?
Thanks,
Daniel
