EG800GEU_LD quecpython firmware
hi we are using EG800GEU_LD module, we want to know if the module supports quecpython and if yes where do we need to download the firmware?
forum support is so bad, we often ask questions but never get answers.
@Felix.feng-Q
hi, Linh
I’m very sorry to have caused you trouble.
We do not recommend using the EG800GEU_LD. Please refer to this link to select a suitable model.
Product selector | QuecDevZone
Hello, after your product selection suggestion, we have ordered 5 EC800ECNLE modules for testing, but unfortunately we cannot find the firmware for the said module, although it is in the support suggestion list for Quecpython, we have downloaded the firmware for EC800ECNLC version, but unfortunately when using QPYcom and QFlash both cannot download the firmware for the module, although I have installed the full driver. There is something strange that when we connect to the AT port, and check the module information via ATI command, the module responds: Quectel EC800E Revision: EC800ECNLCR01A21M04 Please reply soon, we have a project to deploy urgently
I’m sorry for the late reply.
May I ask if you plan to use the EC800E?
As far as I know, the EC800E may not be a mainstream model at present.
If you need the firmware for EC800E, please provide your email address, and I will send the firmware to you via email.
my email: chuoichin1012@gmail.com
I understand your issue. Your problem is that the firmware fails to download, right?
EC800E needs to enter forced download mode before the firmware can be downloaded.
The method is as follows:
Before powering on the module, pull down USB_BOOT (Pin82) to GND . When powered on, the module will enter forced download mode .
