EG800AK-CN (11LG): gnssconfig rejects every write (stuck at BDS only) - need Standard AT firmware with GPS+BDS
ello Quectel team,
We are developing a body-worn camera for police/security use in India on the EG800AK-CN, controlled by an external MCU over the main UART with standard AT commands (not QuecOpen / QuecPython). Volume production is planned. LTE, MQTT, TCP and GNSS all work. The one thing we cannot do is change the GNSS constellation from the default BDS-only to GPS + BDS.
Module information
  • Model: EG800AK-CN, EG800AKCN11LG (EG800AKCN11LG-4I-SGNSA)
  • Firmware (AT+QGMR): EG800AKCN11LGR07A05M04
  • GNSS (AT+QGPSINFO): CC1177W, G1B1, N1080R3.23.1.3269Build18385
Problem
AT+QGPSCFG=? → +QGPSCFG: “gnssconfig”,(0,1,3,4,5,6,7)
AT+QGPSCFG=“gnssconfig” → +QGPSCFG: “gnssconfig”,7
AT+QGPSCFG=“gnssconfig”,1 → ERROR
Every write returns ERROR, including “gnssconfig”,7 (the current value). Only $GBGSV/$GBGSA are output; indoors we get only 4-6 satellites.
The GNSS Application Note V1.1 lists gnssconfig 0-8 for the EG800AK series (including 1 = GPS+BDS and 2 = GPS+BDS+GLONASS+Galileo), but our firmware only lists 0,1,3-7 and rejects all writes, so we believe our firmware is older than the document.
Tried (all ERROR): all values 0-8; GNSS stopped (AT+QGPSEND) and running; right after module reset; AT+CFUN=4 and 0; outport none/uartdebug/usbnmea; nmeasrc 0/1; autogps, apflash and AT+QAGPS each 0 and 1; AT+CMEE=2 still gives plain ERROR. All other QGPSCFG items can be written.
Two other issues found
  1. AT+QGPSDEL=0/1/2 always returns ERROR (AT+QGPSDEL=? lists 0-2).
  2. With UART at 1,000,000 baud (AT+IPR=1000000) GNSS freezes about 1 s after the rate change and AT+QGPS=1 makes the module stop responding within about 5 s. At 921600 and 115200 GNSS works well (3D fix, 10-13 satellites, HDOP ~1.0).
Request
  1. Please send the latest Standard firmware (AT commands, non-OpenCPU) for EG800AKCN11LG with GNSS support and writable gnssconfig (GPS + BDS), plus the QFlash tool and flashing guide (or a DFOTA package from R07A05M04).
  2. The meaning of gnssconfig values 0-8 on the EG800AK.
  3. Whether the QGPSDEL and 1 Mbaud issues are fixed in newer firmware.
We have also submitted this through the quectel.com technical support form. Full logs available on request. Thank you!
Hi @Desai_Rohith_Reddy
I will send the latest FW through the email. Kindly check on your side.
Hi @Firdaus, thank you. I’ve received the firmware R07A07M04 by email and replied there with our project details.
One note for others reading this thread: our board is UART-only (no USB to the module), so we’ve asked for a DFOTA delta package from R07A05M04 instead of the QFlash package. I’ll update this thread once we’ve tested whether gnssconfig (GPS + BDS) can be changed on R07A07M04.
