Hello Quectel Support Team,
We are currently working with the EG800K module.
When we try to turn on the GNSS by sending the AT+QGPS=0 command, we consistently get an ERROR response.
Could you please clarify the following points regarding this module?
- why is it returning error?
- Is there any way to disable internal gnss antenna by default since we are using L89 external antenna?
Best regards
Hi @Jestin_P_Shaji
The AT+QGPS command uses parameter 0 to disable GNSS functionality, and 1 to enable GNSS. Sending AT+QGPS=0 to turn on GNSS is the direct cause of the ERROR response. Send AT+QGPS=1.
Do you mean the internal antenna on the L89 GNSS module? by default, the L89 antenna mode was set to Automatic.
Can query the antenna mode using the below command:
If you want to permanently set the L89 to use the external antenna only, you can use the following command:
$PQTMCFGANTENNA,1,2*06
Here, 2 means external antenna only mode.
Kindly refer to protocol document:
See page 33 under chapter 2.3.2. PQTMCFGANTENNA
