EG25GLGA-MINIPCIE: Is VoLTE supported and enabled by default?
Hi Quectel Support,
Could you confirm whether the EG25GLGA-MINIPCIE supports incoming and outgoing VoLTE calls with its factory firmware? The EG25-GL Mini PCIe datasheet lists VoLTE as optional, so I’d like to confirm support for this exact ordering code.
If supported, is IMS enabled by default, or does it require an AT command, a specific firmware version, or a carrier MBN profile?
Thanks.
Hi @wei_chan
I have sent an email to follow up through your email address. Kindly check on your side.
