I’m using an EG25-G on a Raspberry Pi Zero W, with a USB Hub, so power is independent of the Pi.
I have a bunch of images of 5MB stored in an SD, and every 5 min I upload one of these images to Dropbox. This system was working very fine until a few days. I can connect to the system using the EG25, it does upload a proxy of the same images, around 100kb every 5 min, but when I try to upload the 5MB image it either resets the connection or the Pi crashes.
If I split the file in 1MB and send it one by one there is no problem.
From log/messages:
Jul 1 17:02:46 Pi kernel: [ 322.157057] usb 1-1.3: USB disconnect, device number 4
Jul 1 17:02:46 Pi kernel: [ 322.158047] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Jul 1 17:02:46 Pi kernel: [ 322.158195] option 1-1.3:1.0: device disconnected
Jul 1 17:02:46 Pi kernel: [ 322.159218] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Jul 1 17:02:46 Pi kernel: [ 322.159362] option 1-1.3:1.1: device disconnected
Jul 1 17:02:46 Pi kernel: [ 322.160328] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
Jul 1 17:02:46 Pi kernel: [ 322.160497] option 1-1.3:1.2: device disconnected
Jul 1 17:02:46 Pi kernel: [ 322.167912] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
Jul 1 17:02:46 Pi kernel: [ 322.168096] option 1-1.3:1.3: device disconnected
Jul 1 17:02:46 Pi kernel: [ 322.169491] qmi_wwan 1-1.3:1.4 wwan0: unregister ‘qmi_wwan’ usb-3f980000.usb-1.3, WWAN/QMI device
Jul 1 17:02:59 Pi kernel: [ 335.350080] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
Jul 1 17:02:59 Pi kernel: [ 335.590160] usb 1-1.3: New USB device found, idVendor=2c7c, idProduct=0125, bcdDevice= 3.18
Jul 1 17:02:59 Pi kernel: [ 335.590197] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
Jul 1 17:02:59 Pi kernel: [ 335.590217] usb 1-1.3: Product: EG25-G
Jul 1 17:02:59 Pi kernel: [ 335.590234] usb 1-1.3: Manufacturer: Quectel
Jul 1 17:02:59 Pi kernel: [ 335.591820] option 1-1.3:1.0: GSM modem (1-port) converter detected
Jul 1 17:02:59 Pi kernel: [ 335.592253] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB0
Jul 1 17:02:59 Pi kernel: [ 335.592966] option 1-1.3:1.1: GSM modem (1-port) converter detected
Jul 1 17:02:59 Pi kernel: [ 335.593536] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB1
Jul 1 17:02:59 Pi kernel: [ 335.594653] option 1-1.3:1.2: GSM modem (1-port) converter detected
Jul 1 17:02:59 Pi kernel: [ 335.595179] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB2
Jul 1 17:02:59 Pi kernel: [ 335.596035] option 1-1.3:1.3: GSM modem (1-port) converter detected
Jul 1 17:02:59 Pi kernel: [ 335.596519] usb 1-1.3: GSM modem (1-port) converter now attached to ttyUSB3
Jul 1 17:02:59 Pi kernel: [ 335.597926] qmi_wwan 1-1.3:1.4: cdc-wdm0: USB WDM device
Jul 1 17:02:59 Pi kernel: [ 335.599237] qmi_wwan 1-1.3:1.4 wwan0: register ‘qmi_wwan’ at usb-3f980000.usb-1.3, WWAN/QMI device, 2e:4f:e3:4b:xx:xx
Jul 1 17:02:59 Pi mtp-probe: checking bus 1, device 5: “/sys/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3”
Jul 1 17:02:59 Pi mtp-probe: bus: 1, device: 5 was not an MTP device
Versions:
EG25GGBR07A08M2G
QConnectManager_Linux_V1.6.1
qmi_wwan driver version = 5.15.76-v7+
Linux Pi 5.15.76-v7+ #1597 SMP Fri Nov 4 12:13:17 GMT 2022 armv7l GNU/Linux
Raspbian GNU/Linux 11 (bullseye)
Any ideas?
