I am facing an issue connecting my Quectel EG25 GSM modem to the Azure event grid MQTT broker. Each time I upload the certificates and try to open a connection to the broker, it returns me +QMTOPEN: 0,-1.
I have generated the certificates using openSSL. The certificates are working fine when using MQTTx.
I have generated certificates using openSSL. Please help me out how to upload certificates on my modem.
I am currently using the uart terminal to give commands to modem using a PC.
Hi @Devesh_Pareek
I have sent you the latest firmware, you can upgrade to the latest firmware first and try it. If it still doesn’t work, please use qwinlog to grab a log containing the complete connection, I will have a look at it, thank you.
I’m trying to connect and send a simple test message to my Azure MQTT IoT hub, using AT commands, the server rejects all my connections.
My EC25-A has Version: EC25AFAR05A07M4G_30.002.30.002
Should it work ? Does my EC25-A should be able to connect to Azure MQTT server in secure port?
It works well with a non secured port 1883…
Thanks , Rami.
