We are trying to do DFOTA on EG25 Modem from host micro controller. We were uploaded file into UFS.
Then sent AT command
AT+QFOTADL="/data/ufs/EG25.zip"
unfortunately we were not able to log debug massages.
While doing that Modem stops giving responses.
Is there any way to recover the modem?
Could you also provide EG25 Modem firmware EG25GGBR07A07M2G and utility to update EG25 Modem?
Dear Skarkare,
Please note that when you upgrade the module firmware via DFOTA, please make sure do not send any command to module or any operation to control the module till the upgrade finished. You can use UART port to check the process, not USB port, before it will reset the module when upgrading automatically. Thanks!
For the firmware package, please contact support@quectel.com to get it. Thanks!
