Hello Quectel Team,
I have a Quectel EG25-GL_D Mini PCIe module with the following firmware:
```text
Model: EG25-GL_D
Revision: EG25GLGDR07A03M1G
Firmware: EG25GLGDR07A03M1G_A0.300.A0.300
Hardware: M1G
I am currently using an EE UK / EE roaming SIM and would like to use LTE data and, if supported, VoLTE/IMS on the EE network.
I checked the current MBN list with:
```text
AT+QMBNCFG=“list”
but there is no `Commercial-EE` profile included.
The current firmware contains profiles such as:
```text
ROW_Generic_3GPP
VoLTE-ATT
CDMAless-Verizon
Commercial-TMO_VoLTE
Commercial-DT
TF_Germany_VoLTE
TF_Spain_VoLTE
VoLTE_OPNMKT_CT
Telstra-Commercial_VoLTE
Commercial-KDDI
Commercial-DCM
Commercial-SKT
Commercial-KT
Commercial-LGU
Commercial-Do-Rogers
but no EE / UK profile.
Could you please provide:
1. The **latest firmware** compatible with `EG25GLGDR07A03M1G / M1G`;
2. The corresponding **QFirehose/QFlash upgrade tool**, if required;
3. The firmware **release notes**;
4. A firmware version that includes the **Commercial-EE / EE UK MBN**, if available;
5. If the EE MBN is not included in the latest firmware, could you please provide the **compatible Commercial-EE MBN/MCFG profile** separately?
6. If EE VoLTE/IMS requires specific configuration, please also advise the recommended configuration for EE UK roaming.
I can provide the complete `AT+QMBNCFG=“list”` output and additional modem/IMS logs if needed.
My current firmware is working for basic LTE connectivity, but I specifically need the EE carrier MBN/profile for better EE UK roaming and IMS/VoLTE compatibility.
Thank you very much for your help.
