Dear,
Could you please help me with the following problem?
I was testing the EG25-G module. During the test I did set up the baud rate 256000 which, as I realized later, is not supported.
I used the command AT+IPR=256000;&W.
Is there some possible way to restart the module to default baud rate 115200?
At this moment the module is not responding to any AT command.
Thank you for your support.
Best regards
Stanislav Janek
