Hi all - intermittently getting these errors with the usb device dropping out, then coming back.
Sometimes it is associated with traffic, other times not. Any idea on what the next step is for debugging?
[ 2174.078539] usb usb1-port1: disabled by hub (EMI?), re-enabling…
[ 2174.084819] usb 1-1: USB disconnect, device number 9
Evaluation kit: MINIPCIE-EVB-KIT Q1 A2330 MP823AB2000069
Board : EG25-G
Quectel Connection Manager 1.6.7
Linux QMI_WWAN_Q driver 1.2.6.1
All cables/antennas are from the evaluation kit.
./quectel-CM -s ESEYE1 USER PASS 3 -4 &
[2] 1787
[1] Done ./quectel-CM -s ESEYE1 USER PASS 3 -4
[10-02_12:52:18:597] QConnectManager_Linux_V1.6.7
[10-02_12:52:18:598] Find /sys/bus/usb/devices/1-1 idVendor=0x2c7c idProduct=0x125, bus=0x001, dev=0x00a
root@am64xx-evm:/usr/share/quectel# [10-02_12:52:18:611] Auto find qmichannel = /dev/cdc-wdm0
[10-02_12:52:18:611] Auto find usbnet_adapter = wwu1i4
[10-02_12:52:18:611] netcard driver = qmi_wwan_q, driver version = V1.2.6.1
[10-02_12:52:18:612] Modem works in QMI mode
[10-02_12:52:18:624] cdc_wdm_fd = 7
[10-02_12:52:18:718] Get clientWDS = 17
[10-02_12:52:18:750] Get clientDMS = 1
[10-02_12:52:18:782] Get clientNAS = 3
[10-02_12:52:18:815] Get clientUIM = 2
[10-02_12:52:18:846] Get clientWDA = 1
[10-02_12:52:18:878] requestBaseBandVersion EG25GGBR07A08M2G
[10-02_12:52:19:006] requestGetSIMStatus SIMStatus: SIM_READY
[10-02_12:52:19:071] requestGetProfile[pdp:1 index:1] ESEYE1/USER/PASS/3/IPV4
[10-02_12:52:19:071] requestSetProfile[pdp:1 index:1] ESEYE1/USER/PASS/3/IPV4
[10-02_12:52:19:072] no need to set skip the rest
[10-02_12:52:19:102] requestRegistrationState2 MCC: 238, MNC: 20, PS: Attached, DataCap: LTE
[10-02_12:52:19:135] requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
[10-02_12:52:19:136] ip addr flush dev wwu1i4
[10-02_12:52:19:147] ip link set dev wwu1i4 down
[10-02_12:52:19:199] requestSetupDataCall WdsConnectionIPv4Handle: 0x8740af50
[10-02_12:52:19:328] change mtu 1500 -> 1430
[10-02_12:52:19:329] ip link set dev wwu1i4 up
[10-02_12:52:19:343] busybox udhcpc -f -n -q -t 5 -i wwu1i4
udhcpc: started, v1.36.1
udhcpc: broadcasting discover
udhcpc: broadcasting select for 10.74.80.2, server 10.74.80.1
udhcpc: lease of 10.74.80.2 obtained from 10.74.80.1, lease time 7200
[10-02_12:52:19:492] /usr/share/udhcpc/default.script: Resetting default routes
SIOCDELRT: No such process
[10-02_12:52:19:506] /usr/share/udhcpc/default.script: Adding DNS 192.168.111.2
[10-02_12:52:19:506] /usr/share/udhcpc/default.script: Adding DNS 192.168.112.2
Dropped protocol specifier '.udhcpc' from 'wwu1i4.udhcpc'. Using 'wwu1i4' (ifindex=14).
[ 2996.560810] usb usb1-port1: disabled by hub (EMI?), re-enabling...
[ 2996.567066] usb 1-1: USB disconnect, device number 10
[ 2996.574078] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
[ 2996.586019] option 1-1:1.0: device disconnected
[ 2996.597919] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
[ 2996.606327] option 1-1:1.1: device disconnected
[ 2996.612856] option1 ttyUSB2: GSM modem (1-port) converter now disconnected from ttyUSB2
[ 2996.627858] option 1-1:1.2: device disconnected
[ 2996.635698] option1 ttyUSB3: GSM modem (1-port) converter now disconnected from ttyUSB3
[ 2996.648711] option 1-1:1.3: device disconnected
[ 2996.654574] qmi_wwan_q 1-1:1.4 wwu1i4: unregister 'qmi_wwan_q' usb-xhci-hcd.6.auto-1, WWAN/QMI Raw IP device
[10-02_12:52:24:232] QmiWwanThread poll err/hup/inval
[10-02_12:52:24:232] poll fd = 7, events = 0x0018
[10-02_12:52:24:233] QmiWwanThread exit
[10-02_12:52:24:233] ip addr flush dev wwu1i4
Device "wwu1i4" does not exist.
[10-02_12:52:24:269] ip link set dev wwu1i4 down
Cannot find device "wwu1i4"
[10-02_12:52:24:307] qmi_main exit
[ 2996.964907] usb 1-1: new high-speed USB device number 11 using xhci-hcd
[ 2997.137321] option 1-1:1.0: GSM modem (1-port) converter detected
[ 2997.144127] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB0
[ 2997.156181] option 1-1:1.1: GSM modem (1-port) converter detected
[ 2997.163051] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB1
[ 2997.173263] option 1-1:1.2: GSM modem (1-port) converter detected
[ 2997.181254] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB2
[ 2997.188797] option 1-1:1.3: GSM modem (1-port) converter detected
[ 2997.195623] usb 1-1: GSM modem (1-port) converter now attached to ttyUSB3
[ 2997.209427] qmi_wwan_q 1-1:1.4: cdc-wdm0: USB WDM device
[ 2997.215925] qmi_wwan_q 1-1:1.4: Quectel EG25-G work on RawIP mode
[ 2997.224233] qmi_wwan_q 1-1:1.4: rx_urb_size = 1520
[ 2997.230559] qmi_wwan_q 1-1:1.4 wwan0: register 'qmi_wwan_q' at usb-xhci-hcd.6.auto-1, WWAN/QMI Raw IP device, 9e:09:1f:6e:ce:b2
[ 2997.431314] qmi_wwan_q 1-1:1.4 wwu1i4: renamed from wwan0
