Eg25-g SMS Read
Hi
Even though i set to SM but it goes to ME, How do i set this?
AT+CPMS=“SM”,“SM”,“SM”
+CPMS: 9,10,9,10,9,10
+CMTI: ,2
+CMTI: “ME”,0 /// if any sms i send still falls on some random ME ?
Pls guide to get SMS read from SM .
You have 9 SMSs on the SIM, with one of 10 slots unused. To read:
AT+CPMS="SM","SM","SM"
AT+CMGF=1
AT+CMGL="ALL"
with the above commands
+COPS: 0,0,“JIO 4G Jio”,7
+CMGL: 0,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/10,12:13:55+22”
00480065006C006C006F0020004400610069006B006F006B00750020
+CMGL: 1,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/10,12:14:21+22”
004800690020004E006900740069006E0020
+CMGL: 2,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/10,12:15:08+22”
004800690020004B006800750073006800690020
+CMGL: 3,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/10,12:29:23+22”
00480069
+CMGL: 4,“REC READ”,“00350039003000330039003400360035”,“24/07/15,12:54:38+22”
005300490047004E0041004C003A00200059006F0075007200200063006F00640065002000690073003A0020003300380037003300300031000A0044006F0020006E006F00740020007300680061007200650020007400680069007300200063006F00640065
+CMGL: 5,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/15,12:56:00+22”
00560061006E006B0061006D
+CMGL: 6,“REC READ”,“00350039003000330039003400360035”,“24/07/15,12:56:28+22”
005300490047004E0041004C003A00200059006F0075007200200063006F00640065002000690073003A0020003300330034003800360035000A0044006F0020006E006F00740020007300680061007200650020007400680069007300200063006F00640065
+CMGL: 7,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/15,18:09:42+22”
+CMGL: 8,“REC READ”,“002B003900310039003400380030003700320033003200350033”,“24/07/15,18:10:38+22”
004E0061006D00610073007400650020
+CMTI: ,3 ///when sms is sent, its not specifying the memory why?
AT+CPMS=“ME” ///used to set
Your SMSs are all encoded as 16-bit unicode, and not the usual 7-bit GSM default alphabet.
They were encoded this way by the SMS sender.
The first unicode character in the first message is “002B”. This is the ASCII character “+”, and will be part of the originator address.
The message proper starts with the “0048” on the next line. This is ASCII “H”.
The full line “00480065006C006C006F0020004400610069006B006F006B00750020” decodes as: "Hello Daiku ".
16-bit SMSs can hold a maximum of 70 unicode characters. This is reduced further when the SMS is divided into message parts, due to the part numbering mechanism.
This is an unsolicited result code. The format is: +CMTI: <mem>,<index> where the <index> value of 3 means message number 3 (beginning from zero).
That sets <mem1> to ME storage. <mem1> is the memory from which SMSs are read.
We are using SIERRA WIRELESS: A SEMTECH COMPANY
SIM with EG25-g, SIM vendor is saying to enable Service Domain Configuration
PS and CS to be enabled on the device.
How do i check with this issue?
AT+QOPS
+QOPS: “IND airtel”,“airtel”,“40445”
1,“2G”,52,61D1,59DB,0,55,45,0,1
2,“2G”,59,61D1,59D9,0,54,44,0,1
3,“2G”,53,61D1,F46B,0,51,41,0,1
4,“2G”,51,61D1,F46D,0,44,34,0,1
5,“4G”,3626,290,2151,C4FBF2A,-76,-13,0
6,“4G”,39125,290,2151,C4FBF02,-88,-14,0
7,“4G”,1301,290,2151,339A90C,-90,-15,0
8,“4G”,240,290,2151,339A920,-90,-16,0
9,“4G”,39275,290,2151,C4FBF16,-90,-13,0
10,“4G”,2190,290,2151,339A920,-92,-16,0
+QOPS: “Vodafone IN”,“Vodafone”,“40486”
1,“2G”,667,7A45,935B,0,52,47,0,1
2,“2G”,669,7A45,9C87,0,41,36,0,1
3,“2G”,738,7A45,935A,0,40,35,0,1
4,“4G”,3576,449,3ADD,C3C360B,-78,-15,0
5,“4G”,1582,295,3ADD,C3C3608,-82,-11,0
6,“4G”,340,443,3ADD,C44A71F,-87,-12,0
7,“4G”,2290,443,3ADD,C44A71F,-88,-12,0
+QOPS: “CellOne”,“CellOne”,“40471”
1,“2G”,107,55F0,FD22,0,35,30,0,1
2,“3G”,10782,397,28CC,1F8FD26,-92,12,0
+QOPS: “IND-JIO”,“JIO”,“405861”
1,“4G”,8853,188,11,107932,-72,-12,0
2,“4G”,2463,188,11,107932,-72,-12,0
3,“4G”,1451,503,11,107925,-89,-10,0
4,“4G”,38948,350,11,10791B,-93,-15,0
5,“4G”,38750,316,11,107918,-93,-14,0
+QOPS: “Reliance”,“Reliance”,“40510”
4,“4G”,38750,316,11,107918,-93,-14,0
+CIND: 0,4,1,0,1,0,1,0
+QSPN: “IND airtel”,“airtel”,“Sierra Wireless”,0,“40445”
PS preferred command, with CS as fallback: AT+CGSMS=2
AT+CGSMS?
Where:
0 - PS only
1 - CS only
2 - PS preferred
3 - CS preferred
I checked with both setting AT+CGSMS=2 and 3, still i am not able to receive any sms. But when i put sim over android phone, i start receiving SMS.
Why is this happening with EG25-G Modem, what i am missing to set? to get SMS over Sierra Wireless SIM?
You had 9 SMSs on the SIM at that point. Unless you know otherwise, these will almost certainly be received SMSs.
What does AT+CPMS? return now?
Might the reason you’re not receiving further SMSs be that storage is full?
Are your <mem1> and <mem3> storage settings the same in the +CPMS: result?
But into which storage, “ME” or “SM”?
+CPMS: 9,10,9,10,9,10 /// Previously we have achieved this with loacl sim, We are facing issue with Sierra Wireless SIM.
Bellow are the Output from Sierra Wireless SIM
+CPMS: “SR”,0,3,“MT”,0,255,“MT”,0,255
+CPMS: 0,50,0,50,0,50
+CPMS: “SM”,0,50,“SM”,0,50,“SM”,0,50
+CGSMS: 3
+CGSMS: 2
Still we do not see any message receiving.
Can you send SMSs with the Semtech SIM?
What do these AT commands return?
AT+CSCA?
AT+QENG="servingcell"
AT+CSCA?
+CSCA: “002B003800380033003100330030003000300030003000300038003300320030”,145
AT+QENG=“servingcell”
+QENG: “servingcell”,“NOCONN”,“LTE”,“FDD”,404,45,339A90A,262,1301,3,5,5,2151,-91,-15,-56,-2,32
We are not able send SMS too.
This is odd. Your SMS message centre number is being displayed in 16-bit unicode instead of ASCII.
Please post the results of these AT commands to help me figure out what is happening:
AT+CSCS?
AT+CSCS=?
AT+QMBNCFG="List"
Please always show the command being executed immediately before showing the result.
AT
AT+CSCS?
+CSCS: “GSM”
AT+CSCS=?
+CSCS: (“IRA”,“GSM”,“UCS2”)
+CIND: 0,5,1,0,1,0,1,0
AT+QMBNCFG=“List”
+QMBNCFG: “List”,0,1,1,“ROW_Generic_3GPP”,0x0501081F,202112292
+QMBNCFG: “List”,1,0,0,“VoLTE-ATT”,0x0501033C,202203251
+QMBNCFG: “List”,2,0,0,“hVoLTE-Verizon”,0x05010141,202302081
+QMBNCFG: “List”,3,0,0,“Sprint-VoLTE”,0x05010205,202010201
+QMBNCFG: “List”,4,0,0,“Commercial-TMO_VoLTE”,0x05010505,202301051
+QMBNCFG: “List”,5,0,0,“Telus-Commercial_DO”,0x0580F601,202105061
+QMBNCFG: “List”,6,0,0,“Commercial-SBM”,0x05011C18,202303021
+QMBNCFG: “List”,7,0,0,“Commercial-DT”,0x05011F1C,202210091
+QMBNCFG: “List”,8,0,0,“Reliance_OpnMkt”,0x05011B38,202003251
+QMBNCFG: “List”,9,0,0,“TF_Germany_VoLTE”,0x05010C1B,202004151
+QMBNCFG: “List”,10,0,0,“TF_Spain_VoLTE”,0x05010CFA,202212161
+QMBNCFG: “List”,11,0,0,“Volte_OpenMkt-Commercial-CMCC”,0x05012071,202303133
+QMBNCFG: “List”,12,0,0,“VoLTE_OPNMKT_CT”,0x050113FC,202301161
+QMBNCFG: “List”,13,0,0,“CU-VoLTE”,0x05011508,202212271
+QMBNCFG: “List”,14,0,0,“Telstra-Commercial_VoLTE”,0x0580079E,202211231
+QMBNCFG: “List”,15,0,0,“Commercial-KDDI”,0x0501071D,202303091
+QMBNCFG: “List”,16,0,0,“Commercial-DCM”,0x05010D17,202203141
+QMBNCFG: “List”,17,0,0,“Commercial-SKT”,0x05012715,202212101
+QMBNCFG: “List”,18,0,0,“Commercial-KT”,0x05012C0D,202211101
+QMBNCFG: “List”,19,0,0,“Commercial-LGU”,0x05012626,202301171
+QMBNCFG: “List”,20,0,0,“Commercial-USCC”,0x0504FC40,202203021
+QMBNCFG: “List”,21,0,0,“Optus-Commercial_VoLTE”,0x05800CA2,201910241
+QMBNCFG: “List”,22,0,0,“STC_Saudi_VoLTE”,0x0501FE01,201912231
+QMBNCFG: “List”,23,0,0,“Commercial-Rogers”,0x05018821,202202091
I would try changing the character set to “IRA” with:
AT+CSCS="IRA"
But I don’t know if that will help.
Your active MBN file “ROW_Generic_3GPP” shouldn’t affect the display of the SMS service centre number (SMSC).
“002B003800380033003100330030003000300030003000300038003300320030” decodes to “+883130000008320” and I can find no reference to such an SMSC.
Have you been given the correct SMSC number for this SIM?
+CSCS: “UCS2”
+CSQ: 28,99
+CSCS: “IRA”
Ya, that is the correct number.
Still i do not see SMS are received.
Please try setting the SMSC number to its ASCII form:
AT+CSCA="+883130000008320",145
Please also post the result of:
AT+CIND=?
+CIND: (“battchg”,(0-5)),(“signal”,(0-5)),(“service”,(0-1)),(“call”,(0-1)),(“roam”,(0-1)),(“smsfull”,(0-1)),(“GPRS coverage”,(0-1)),(“callsetup”,(0-3))
+CSCA: “+883130000008320”,145
Still seems to be same even after setting with the above.
Sim Phone Number +12056320463, International SIM working on Roaming, this is for your kind information for further assistance.
What does AT+CNMI? return?
