Hello!
Please tell me about the EG25-G module.
I am using two different lots of modules and the size of the SMS message storage for each ME is different.
One has 255 storages and the other has 23.
The size of the storage was confirmed by “AT+CPMS?”.
Is it possible to change this storage size?
If so, how?
If not, how can I distinguish the difference between the two modules? For example, the type name…
Please print the result of your query
What are the respective firmware versions of the two problems?
Hello Herbert.
The firmware of the two lots was the same.
Q1-A8008: EG25GGBR07A08M2G
Q1-A7611: EG25GGBR07A08M2G
please run the AT command to query software version
AT+QGMR
There was a difference.
Q1-A8008: EG25GGBR07A08M2G_30.005.30.005
Q1-A7611: EG25GGBR07A08M2G_01.003.01.003
The two firmware sub-versions are different. There may be some fixes, which may result in different query results. You can upgrade or refresh the version to check
Hello
Thank you for your reply.
Could you provide me with the latest firmware for EG25-G or tell the link URL?
I have sent the latest firmware to your email
Thank you. I received the file.
