EG25-G on ECM mode with rapberry pi
Hello, I try setup EG25-G on Raspberry Pi 4 to work on ECM mode. Modem connects, but I cannot see network devices on linux side. Any ideas?
Is this problem on EG25-G side or on Raspberry? Any firmware update to EG25-G?
This what I have done on EG25-G
AT+QCFG=“usbnet”,1
AT+CGDCONT=1,“IP”,“iot.1nce.net
AT+CFUN=1,1
AT+CPIN?
+CPIN: READY
AT+CREG?
+CREG: 0,5
AT+CGCONTRDP
+CGCONTRDP: 1,5,iot.1nce.net,100.113.164.1,8.8.8.8,8.8.4.4
AT+CGMR
EG25GGBR07A07M2G
And dmesg from linux
I suggest that you can upgrade the firmware to R07A08 version, you can send an email to support@quectel.com to get the firmware.
Thanks, just send it.
This is a me-too. I have the same problem, the firmware I have is EC25EUXGAR08A13M1G.
All seems correct, but there is no connectivity to then network. I am using AT+QCFG=“usbnet”,1 which gives me a local interface usb0, with an IP address of 192.168.225.30
The SIM does work in an A767X module, but we are converging to Quectel.
Thanks.
According to the release note it is supported.
It is better to check whether it is regsterred with your SIM card.
