EG25-G Firmware Update Request
Hi there,
Please send the latest EG25-G firmware. Thank you!
Please provide your current firmware version
AT+QGMR output is: EG25GGBR07A08M2G_30.006.30.006
I have EG25GGBR07A08M2G_30.004.30.004. Can I also get the latest?
ATI+QGMR
EG25
Revision: EG25GGBR07A08M2G
Hi, can you help with lates fw? my revision EG25GGBR07A08M2G_01.002.07
Thanks!
@herbert.pan-Q;
Would you be able to verify if I’m using the latest FW?
I travel a lot between the Netherlands and Ireland, and when I arrive in Ireland, I seem to be having a lot of difficulty getting a network fix on 4G network in Dublin.
Eventually it will connect, but it can take up to 1 day sometimes.
My current FW version is: EG25GGBR07A08M2G_30.007.30.007
could you please send the latest firmware?
my current revision: EG25GGBR07A08M2G_01.001.01.001
Thanks,
I want to request the firmware update as well, with the QFlash tool if possible.
EG25GGBR07A07M2G_01.001.01.001
I have sent the latest firmware to your email,pls check,I hope you can click :yellow_heart: for me,thx
I have sent the latest firmware and Qflash to your email,pls check,I hope you can click :yellow_heart: for me,thx
Please firmware update for my
EG25
Revision: EG25GGCR07A02M1G
SubEdition: V02
VERSION: EG25GGCR07A02M1G
Sep 6 2023 12:58:09
Authors: QCT
EG25
EG25GGCR07A02M1G_30.202.30.202
Thanks a lot :yellow_heart:
nico
I have purchased EG25-g module at mouser and it is stuck in DL mode:
Qualcomm Sahara / Firehose Client V3.62 (c) B.Kerler 2018-2025.
main - Using loader prog_nand_firehose_9x07.mbn …
main - Waiting for the device
main - Device detected :slight_smile:
sahara - Protocol version: 2, Version supported: 1
main - Mode detected: sahara
sahara -
Version 0x2
HWID: 0x000480e100000000 (MSM_ID:0x000480e1,OEM_ID:0x0000,MODEL_ID:0x0000)
CPU detected: “MDM9207”
PK_HASH: 0xcc3153a80293939b90d02d3bf8b23e0292e452fef662c74998421adad42a380f
Serial: 0x00190958
sahara - Uploading loader prog_nand_firehose_9x07.mbn …
sahara - 32-Bit mode detected.
sahara - Firehose mode detected, uploading…
sahara - Loader successfully uploaded.
main - Trying to connect to firehose loader …
firehose - Supported Functions: program configure power benchmark read getstorageinfo erase nop
firehose_client
firehose_client - [LIB]: No --memory option set, we assume “eMMC” as default …, if it fails, try using “–memory” with “UFS”,“NAND” or “spinor” instead !
firehose - TargetName=9x07
firehose - MemoryName=NAND
firehose - Version=
firehose - Trying to read first storage sector…
firehose
firehose - [LIB]: Attribute ‘SECTOR_SIZE_IN_BYTES’=512 must be equal to disk sector size 2048
firehose
firehose - [LIB]: ERROR 4: Line 2193: STORAGE_READ_FAILURE
firehose - Running configure…
firehose - Storage report:
firehose - total_blocks:2048
firehose - block_size:131072
firehose - page_size:2048
firehose - mem_type:NAND
firehose - prod_name:NM1282KSLAXAL
Is it possible to get correct firmware for this?
pls provide the IMEI of device
IMEI: 867652075412494
Thank you
