EG25-G firmware request — VoLTE not registering on Australian carriers
I’m running an EG25-G as a SIP-to-cellular voice gateway (via Asterisk + chan_dongle) and cannot make voice calls, IMS fails to register.
Current firmware:
AT+CGMM: EG25
AT+QGMR: EG25GLGDR07A02M1G_01.200.01.200
IMEI: 869387062838553
Carrier: Telstra (Australia, MCC/MNC 505/01)
  • All Australian carriers have shut down 2G and 3G - voice requires VoLTE
  • The Telstra MBN profile is loaded and active (Telstra-Commercial_VoLTE, index 14)
  • AT+QCFG=“ims” returns 1,0 (enabled)
  • AT+CGDCONT? shows IMS APN on context 2
  • AT+QMBNCFG=“AutoSel”,1 is set
  • Data works fine over QMI/ECM (usb0)
Problem: Every ATD returns NO CARRIER. AT+CEER returns 6,267 (IMS not registered). AT+CIREG? returns ERROR (command not supported on this firmware).
What I’ve tried:
  • Enabling IMS: AT+QCFG=“ims”,1
  • Adding IMS APN: AT+CGDCONT=2,“IPV4V6”,“ims”
  • MBN auto-select enabled
  • AT+QCFG=“ims/imsTestMode”,1 → ERROR (not supported)
  • AT+QCFG=“ims/volte”,1 → not tested yet
  • Verified the SIM makes VoLTE calls fine from a Pixel phone (IMS registered, VoLTE available)
Could you provide the latest EG25-G firmware with improved IMS/VoLTE registration for Australian carriers? Ideally a version where AT+CIREG? is supported, so I can debug IMS registration state.
Thank you for the detailed information.
From your description, the data service is working normally and the correct Telstra VoLTE MBN profile is loaded. However, the error +CEER: 6,267 and NO CARRIER during dialing indicate that IMS has not successfully registered, which is why VoLTE calls cannot be established.
Kindly note that IMS/VoLTE behavior is highly dependent on:
  • firmware version
  • MBN profile compatibility
  • operator network requirements
For the EG25-G, some firmware versions have limited IMS debug capability (e.g. AT+CIREG? not supported), and may also have compatibility gaps with certain operators such as Telstra, especially after 3G shutdown.
As for suggestion, I will send you the latest firmware to your email. Please help to upgrade.
Hello OP did the firmware work for your application?
Dear Customer,
May I know if you are facing any issue? If yes, can you describe the issue and provide the current firmware that you are using.
Thank you.
