EG25-G Firmware and win11 driver
Hello!
I need the latest versions of EG25-G Firmware and win11 driver
The firmware version must be international. modems are planned to be used in Russia
Thank you!
Hi @sergnosyrev
Please use the AT+QGMR command to query the detailed information of your current firmware version. I will provide the latest firmware version applicable to your module.
Hi, after driver installation I am able to see AT Port, NMEA Port, DM port but serial port is not detected, what can be the reason?
This is a different interface, you need to connect to a serial port to recognize it.
Yeah, I connected the device with the serial port interface. So I usedthe same connection in EC200 also, and in that I usually see a serial port with all other ports like AT and etc. So is it because of the driver.
Could you also send me the modem firmware that allows Russian SIM cards to work?
