I’m developing an application with EG25-G module.
The firmware version of the module is EG25GGBR07A07M2G.
When the module is turned on, it sends a RDY message on the UART interface.
Once I get this message, I try to read out internal settings that are useful to my application.
When I try to read out information like manufacturer name (AT+GMI?) or firmware version number (AT+GMR?) immediately after receiving the RDY message from the module, I get the correct response.
However, when I try to read the digital audio configuration of the PCM interface (AT+QDAI?) immediately after receiving the RDY message from the module, I get an ERROR response from the module. It responds with AT+QDAI? followed by the word ERROR.
However, when I introduce a 4-5 seconds delay between receiving the RDY message from the module and sending the AT+QDAI? command to it, I get the correct response.
Similarly, when I send the AT+QDAI? or any other audio related command (for egs, AT+CLVL?) command to the module immediately after reading some other parameter (like firmware version number or manufacturer number), I get an ERROR response. But when I introduce a 4-5 second delay between the response to my previous command and sending the new audio related command, I get the correct response.
Is this how it normally behaves?
Thanks in advance.
/Patrik
