We are currently using a Raspberry Pi CM4 with Ubuntu installed on it. (aarch64)
Is it possible if I could get the driver for the Quecetel EG25-G so I can get it to work with Ubuntu. We connect the modem to CM4 via a usb connection.
uname -r returns 5.4.0-1069-raspi
How do I install the driver?
I have tried using “sudo make” to build the Makefile, but unfortunately I get the error “No rule to make target”
Thank you for your response, when I tried your method it did install without issue. However modem, did not detect. I tried 5.9.1 and worked perfectly. Cheers, great stuff! Thanks for your help
Today, the modem failed again. Not sure why signal strength is shown as 0% as I can confirm that this Modem and sim works alright on another version of Linux. Is this a driver issue? Please guide
cheers John
General | path: /org/freedesktop/ModemManager1/Modem/0
| device id: d2cfbcfddcb24a4529910d014e5344c55537e053
Hello, can you use ls /dev/ttyUSB* command to check whether the device port is identified?
If the device port is identified, you can use the Ubuntu debugger to enter debugging mode. The instruction is busybox microcom /dev/ttyUSB2.
After the debugging screen is displayed, run the AT+CPIN? Command. Check whether the device correctly identifies the SIM card. If the SIM card is identified, use AT+COPS? Query the network registration status.
Thanks for your response.
ls /dev/ttyUSB* returns output
" /dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB3
dmesg | grep ttyUSB returns
usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB0
usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB1
usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB2
usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB3
“AT+CPIN?” output is “+CPIN:READY”
“AT+COPS?” returns: 0,0. “Telstra Mobile 1nce.net”, 7
This modem works fine with my other custom board which as a pci-e connection instead of a usb connection.
Yes please thanks. email : scbd2019@gmail.com
I am still unsuccessful in connecting to internet as our new production boards connect via usb and not pci-e.
I only ran sudo make install for the driver. I think on my system, by default ubuntu loads their driver. Will I need to uninstall this driver before installing the latest one?
Can you please send the QMI drivers for this module.
If we are unable to get this module to work, we will have to source a different modem from another manufacturer.
