We are trying to get FCC and ISED certification for our device that uses EG25-G module. For the certification the conducted RF power needs to match the tune-up info of the module.
The tune-up info document states that WCDMA bands have 24dBm+1/-3dB output power but our testing partner has measured 27dBm in UMTS FDD bands II, IV and V. Also the tune-up info document states that LTE TDD conducted output power is 23dBm±2dB but in band 41 was measured to have 19dBm. All other FCC and ISED bands were ok.
What could be the problem? Firmware version mismatch? Is the tune-up document correct?
At least in the EG25-G certification documents the firmware version used was EG25GGBR07A06M4G. We used EG25GGBR07A08M2G 01.002.01.002 version in our certification tests. This could not be the problem?
