We are currently experiencing an issue with an EG25-G device. Although the device successfully establishes a connection, executing the following command: “echo ‘1’ > /proc/sys/net/ipv4/ip_forward” results in a kernel crash, rendering the device unusable until the SBC is restarted. We are seeking the latest firmware version, along with the corresponding drivers and QConnectManager. The system is running on an SBC with Linux 5.10.15 and PowerPC architecture. Please let us know if you require further information. We are also interested in hearing from the community if anyone else has encountered this issue.
Hello @victor.quintero Welcome to Quectel Forum. Members, moderators and the administrators are glad to have you here ![]()
Please contact @Akso.xie or @eddy - They are the administrators, and will gladly assist you.
Alternatively, you are welcomed to email the support: support@quectel.com
More details and even logs are quite welcomed if you can provide when sending your message. This helps the team to faster assist you.
Thanks, Have a nice weekend ![]()
(02-Dec-2023)
Hello,Akso. Xie and Eddy aren’t in charge of the forums category. Each section has corresponding technical moderator responsible. Due to the large number of posts, they need time to reply. Please be patient, and we will also push them to support you as soon as possible.
Thank you for your understanding. ![]()
