Does the EG25-G module generally work on T-Mobile (US) network? I see that certification is “in progress”, I’m just wondering whether it works for other people.
I try to connect like this:
ifconfig wwan0 down
echo Y > /sys/class/net/wwan0/qmi/raw_ip
ifconfig wwan0 up
qmicli -v -d /dev/cdc-wdm0 --wds-start-network=“ip-type=4,apn=‘m2mglobal’” --client-no-release-cid
The result ends with this:
<<<<<< TLV:
<<<<<< type = “Verbose Call End Reason” (0x11)
<<<<<< length = 4
<<<<<< value = 06:00:1A:00
<<<<<< translated = [ type = ‘3gpp’ reason = ‘26’ ]
Dear Jackjohnson,
Normally, EG25G module have not got T-Mobile certificate, you may can try EC25AF which already get the T-Mobile certificate. Thanks!
If that, it may need to catch module debug log to analyze the reason. Before that please confirm your test environment and test method, could you help share a video to record your test steps. Thanks!
