EG21G-MINIPCIE IPV6 Test Failures
We just completed IPV6 testing for the EG21GBB-MINIPCIE using modem FW: EG21GGBR07A11M1G_30.201.30.201
The device fails the following tests:
Test Clause Expectation Respond from NUT
Part E: Most Significant Bits 10b, unicast destination The Code field must be 2 (unrecognized IPv6 Option encountered). Respond with code field 0 (erroneous header field)
Part F: Most Significant Bits 11b, unicast destination The Code field must be 2 (unrecognized IPv6 Option encountered). Respond with code field 0 (erroneous header field)
Part B: Unrecognized Routing Type 0 The Pointer field must be 0x2A (offset of the Routing Type field of the Routing header). Respond with 0x2B (offset of the flagging Segments Left)
This is preventing us from getting approval for our device in that particular country because they require IPV6 testing and it must pass every test.
Wireshark Logs.zip (740 Bytes)
Hi apl,
Thank you for your patience.
I will send via your email. Please have a check. Thank you and have a nice day!
