EG21 Responding with "702" error even though data is sent successfully
I am sending data to a server via an EG21 using AT+QHTTPPOST. Everything is successful - activating PDP, opening socket, setting URL destination etc, but when I attempt to send data with the command “AT+QHTTPPOST=631,15,15” and follow with a data block of the correct size, the EG21 responds with “+QHTTPPOST: 702”. I retry again until a successful response of “+QHTTPPOST: 0,200”.
What this results in is:
EG21
Data Packet 1
+QHTTPPOST: 702
+QHTTPPOST: 702
+QHTTPPOST: 0,200
Data Packet 2
+QHTTPPOST: 702
+QHTTPPOST: 702
+QHTTPPOST: 0,200
Server
Data Packet 1
Received x 3
Data Packet 2
Received x 3
Without fail there will be 2 timeouts and 1 successful.
I’ve tried re-activating the PDP context each time, resetting the GSM module each time, adding in a delay between each HTTPPOST, all with no success.
Is there anything I can do to fix this other than ignoring a 702 error and hoping for the best?
Please add the DNS configuration before QHTTPURL
AT+QIDNSCFG=1,“8.8.8.8”,“8.8.4.4”
Hi, thanks for the reply.
I have already included that command in the setup. Apart from reading the SIM and IMEI etc, this is the list of commands in order used.
AT+CREG?
AT+CGDCONT=1,<PDP_type>,<APN>
AT+QICSGP=1,1,<APN>,<USERNAME>,<PASSWORD>,1
AT+QIACT=1
AT+QIDNSCFG=1,"8.8.8.8","8.8.4.4"
AT+QIDNSGIP=1,<URL>
AT+QHTTPCFG="contextid",1
AT+QHTTPCFG="requestheader",0
AT+QHTTPURL=<URL_LENGTH>
<URL>
AT+QICLOSE=0
AT+QIOPEN=1,0,"TCP",<URL>,80,0,0
AT+QISTATE=1,0
AT+QHTTPPOST=<DATA_LENGTH>,15,15
<DATA>
Could you provide the execution result log of the above-mentioned AT commands?
Here is a snippet of the log printed out from my embedded device (“<” denotes sent to GSM module). The time between sending the data packet and the 702 error is the same time as sending the data packet and a 0,200 reply.
< AT+QICLOSE=0
AT+QICLOSE=0
< AT+QIACT?
AT+QIACT?
+QIACT: 1,1,1,“[IP ADDR]”
< AT+QIDNSCFG=1,“8.8.8.8”,“8.8.4.4”
< AT+QIDNSGIP=1,“[URL]”
< AT+QHTTPCFG=“contextid”,1
< AT+QHTTPCFG=“requestheader”,0
< AT+QHTTPURL=58
AT+QHTTPURL=58
CONNECT
< [URL]
< AT+QICLOSE=0
AT+QICLOSE=0
< AT+QICLOSE=0
AT+QICLOSE=0
< AT+QHTTPPOST=638,15,15
CONNECT
< [DATA PACKET 273]
+QHTTPPOST: 702
CONNECT
< [DATA PACKET 273]
+QHTTPPOST: 702
CONNECT
< [DATA PACKET 273]
+QHTTPPOST: 0,200
CONNECT
< [DATA PACKET 274]
+QHTTPPOST: 702
CONNECT
< [DATA PACKET 274]
+QHTTPPOST: 702
CONNECT
< [DATA PACKET 274]
+QHTTPPOST: 0,200
Based on the log you provided, this error702 is probabilistic. I think it might be caused by an anomaly in the data packets responded by the server to the UE. First of all, I suggest that you can add QPING[URL] before the POST request to check the latency of the server
Why would using Google’s DNS solve his issue?
I have similar problem on the EC200UEU. Works most of the time but sporadically return 702.
The default DNS of the modem is provided by EPC, which may be unable to resolve special urls, especially when the server is deployed in the cloud
I got my issue fixed after updating the firmware to the latest. It seems the module is dropping packets when data is larger in size.
