We have an existing IoT platform that was previously using the Sierra Wireless MC7455. We are looking at switching to the EG21 and hoping that it is mostly a drop-in replacement. We worked through an unrelated issue here involving the establishment of a cell connection to the network.
We’re now looking to get GPS working on this device. We have gpsd previously set up to run with the previous module. So as far as I can tell, this is a matter of getting the NMEA sentences being written to a port that gpsd can read.
I have previously set GPS to automatically run on boot:
AT+QGPSCFG="autogps"
+QGPSCFG: "autogps",1
and I do get location information when querying manually:
AT+QGPSLOC?
+QGPSLOC: 183448.0,43[redacted]N,081[redacted]W,1.1,365.8,3,223.03,0.0,0.0,090224,07
I think this setting may be relevant; it’s set to usbnmea by default.
AT+QGPSCFG="outport"
+QGPSCFG: "outport",usbnmea
I don’t see a GPS/NMEA port listed in ModemManager, though, like I have seen with different modems in the past:
General | dbus path: /org/freedesktop/ModemManager1/Modem/0
| device id: 39c06785d5d506a40d1ddaa901292b089700ed81
Hardware | manufacturer: QUALCOMM INCORPORATED
| model: QUECTEL Mobile Broadband Module
| firmware revision: EG21GGBR07A11M1G
| h/w revision: 10000
| supported: gsm-umts, lte
| current: gsm-umts, lte
| equipment id: 862771047885127
System | device: /sys/devices/soc0/soc/2100000.aips-bus/2184200.usb/ci_hdrc.1/usb1/1-1/1-1.3
| drivers: option1, qmi_wwan
| plugin: Quectel
| primary port: cdc-wdm0
| ports: ttyUSB0 (qcdm), ttyUSB2 (at), cdc-wdm0 (qmi), wwan0 (net),
| ttyUSB3 (at)
Status | lock: sim-pin2
| unlock retries: sim-pin (3), sim-pin2 (10), sim-puk (10), sim-puk2 (10)
| state: connected
| power state: on
| access tech: lte
| signal quality: 47% (recent)
Modes | supported: allowed: 2g; preferred: none
| allowed: 3g; preferred: none
| allowed: 4g; preferred: none
| allowed: 2g, 3g; preferred: 3g
| allowed: 2g, 3g; preferred: 2g
| allowed: 2g, 4g; preferred: 4g
| allowed: 2g, 4g; preferred: 2g
| allowed: 3g, 4g; preferred: 3g
| allowed: 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 4g
| allowed: 2g, 3g, 4g; preferred: 3g
| allowed: 2g, 3g, 4g; preferred: 2g
| current: allowed: 2g, 3g, 4g; preferred: 4g
Bands | supported: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
| utran-8, utran-2, eutran-1, eutran-2, eutran-3, eutran-4, eutran-5,
| eutran-7, eutran-8, eutran-12, eutran-13, eutran-18, eutran-19,
| eutran-20, eutran-25, eutran-26, eutran-28, eutran-38, eutran-39,
| eutran-40, eutran-41, utran-19
| current: egsm, dcs, pcs, g850, utran-1, utran-4, utran-6, utran-5,
IP | supported: ipv4, ipv6, ipv4v6
3GPP | imei: 862771047885127
| operator id: 302220
| registration: roaming
3GPP EPS | ue mode of operation: csps-2
SIM | dbus path: /org/freedesktop/ModemManager1/SIM/0
Bearer | dbus path: /org/freedesktop/ModemManager1/Bearer/0
In simple terms: what’s the best approach for getting gpsd to “see” the GPS location that the module has?
