Hello, i have a zyxel lte5398- m904 with EG18EA, sometime it lose the connection to the ISP and is not able to restore it.
I created a script able to understand when it is offline, but now I need a command able to reset the connection BUT that shall NOT reset the internal memory. Otherwise I have to periodically check if the script is still active.
Actually I am using " cfg cellwan edit --AP_ManualAPN O" but sometime it is not enough.
Can you suggest other commands for this purpose?
