EG18-EA Mikrotik
Device
  • MikroTik LHG LTE18 kit (board: LHGGM)
  • RouterOS: 7.24.4 (stable)
  • Modem: Quectel EG18-EA
  • Firmware: EG18EAPAR01A13M4G_01.300.01.300 (upgraded via RouterOS firmware-upgrade from 01.200.01.200)
  • IMEI: 869816043778801
Problem
Since the upgrade to 01.300.01.300, the modem does not register on the network. It worked on 01.200.01.200 with the same SIM, location and antenna alignment.
RouterOS output:
/interface/lte/firmware-upgrade lte1
  installed: EG18EAPAR01A13M4G_01.300.01.300
     latest: EG18EAPAR01A13M4G_01.300.01.300
       note: This firmware version is not supported in current region
     status: firmware is already up to date
/interface/lte/monitor lte1 once
  status: denied
AT diagnostics
AT+QGMR   -> EG18EAPAR01A13M4G_01.300.01.300
AT+CPIN?  -> +CPIN: READY
AT+CREG?  -> +CREG: 0,2
AT+CEREG? -> +CEREG: 2,2
AT+COPS?  -> +COPS: 0
AT+CEER   -> +CEER: No cause information available
AT+QENG="servingcell" ->
  "servingcell","LIMSRV","LTE","FDD",250,02,...,3048,7,5,5,...,-95,-13,-62,14
Summary
  • SIM is ready. Signal is good (RSRP −95 dBm, RSRQ −13 dB, SINR 14 dB), LTE band 7, operator MCC/MNC 250/02.
  • The modem stays in LIMSRV (limited service), and there is no network reject cause (CEER is empty). The modem itself does not attempt registration.
  • This matches the regional restriction introduced in 01.300.01.300, which other users have reported on the Quectel forum.
Request
Please provide a DFOTA downgrade package from EG18EAPAR01A13M4G_01.300.01.300 to EG18EAPAR01A13M4G_01.200.01.200, so that it can be installed via RouterOS:
/interface/lte/firmware-upgrade lte1 firmware-file=<file or URL> upgrade=yes
The device has only about 1.2 MiB of free storage, so a URL for the package would be ideal. Alternatively, please publish 01.200.01.200 on the MikroTik upgrade server for this model.
Thank you
Hi @Vanance
I have reached out to you via email. Please check
Hello! I have answered the questions in my reply. Please check.
